Multithreaded Programming Guide
pthread_attr_setschedpolicy(3THR)
Use pthread_attr_setschedpolicy(3THR) to set the scheduling policy. The POSIX standard specifies scheduling policy attributes of SCHED_FIFO (first-in-first-out), SCHED_RR (round-robin), or SCHED_OTHER (an implementation-defined method).
SCHED_FIFO and SCHED_RR are optional in POSIX, and are supported for real time bound threads only.
For a discussion of scheduling, see the section Scheduling.
Prototype:
int	pthread_attr_setschedpolicy(pthread_attr_t *tattr, int policy);
#include <pthread.h>
pthread_attr_t tattr;
int policy;
int ret;
/* set the scheduling policy to SCHED_OTHER */
ret = pthread_attr_setschedpolicy(&tattr, SCHED_OTHER);
Return Values
pthread_attr_setschedpolicy() returns zero after completing successfully. Any other return value indicates that an error occurred. When either of the following conditions occurs, the function fails and returns the corresponding value.
EINVAL
An attempt was made to set tattr to a value that is not valid.
ENOTSUP
An attempt was made to set the attribute to an unsupported value.
