Use pthread_attr_setscope(3THR) to create a bound thread (PTHREAD_SCOPE_SYSTEM) or an unbound thread (PTHREAD_SCOPE_PROCESS).
Both thread types are accessible only within a given process.
Prototype: int pthread_attr_setscope(pthread_attr_t *tattr,int scope);
#include <pthread.h> pthread_attr_t tattr; int ret; /* bound thread */ ret = pthread_attr_setscope(&tattr, PTHREAD_SCOPE_SYSTEM); /* unbound thread */ ret = pthread_attr_setscope(&tattr, PTHREAD_SCOPE_PROCESS);
Notice that there are three function calls in this example: one to initialize the attributes, one to set any variations from the default attributes, and one to create the pthreads.
#include <pthread.h> pthread_attr_t attr; pthread_t tid; void start_routine; void arg; int ret; /* initialized with default attributes */ ret = pthread_attr_init (&tattr); /* BOUND behavior */ ret = pthread_attr_setscope(&tattr, PTHREAD_SCOPE_SYSTEM); ret = pthread_create (&tid, &tattr, start_routine, arg);
pthread_attr_setscope() returns zero after completing successfully. Any other return value indicates that an error occurred. If the following conditions occur, the function fails and returns the corresponding value.
