Thread safety is the avoidance of data races—situations in which data are set to either correct or incorrect values, depending upon the order in which multiple threads access and modify the data.
When no sharing is intended, give each thread a private copy of the data. When sharing is important, provide explicit synchronization to make certain that the program behaves in a deterministic manner.
A procedure is thread safe when it is logically correct when executed simultaneously by several threads. At a practical level, it is convenient to recognize three levels of safety.
Unsafe
Thread safe - Serializable
Thread safe - MT-Safe
An unsafe procedure can be made thread safe and serializable by surrounding it with statements to lock and unlock a mutex. Example 6–1shows three simplified implementations of fputs(), initially thread unsafe.
Next is a serializable version of this routine with a single mutex protecting the procedure from concurrent execution problems. Actually, this is stronger synchronization than is usually necessary. When two threads are sending output to different files using fputs(), one need not wait for the other—the threads need synchronization only when they are sharing an output file.
The last version is MT-safe. It uses one lock for each file, allowing two threads to print to different files at the same time. So, a routine is MT-safe when it is thread safe and its execution does not negatively affect performance.
/* not thread-safe */ fputs(const char *s, FILE *stream) { char *p; for (p=s; *p; p++) putc((int)*p, stream); } /* serializable */ fputs(const char *s, FILE *stream) { static mutex_t mut; char *p; mutex_lock(&m); for (p=s; *p; p++) putc((int)*p, stream); mutex_unlock(&m); } /* MT-Safe */ mutex_t m[NFILE]; fputs(const char *s, FILE *stream) { static mutex_t mut; char *p; mutex_lock(&m[fileno(stream)]); for (p=s; *p; p++) putc((int)*p, stream); mutex_unlock(&m[fileno(stream)]0; }
