MT Safety Levels for Libraries
All routines that can potentially be called
by a thread from a multithreaded program should be MT-Safe.
This means that two or more activations of a routine must be able to correctly execute concurrently. So, every library interface that
a multithreaded program uses must be MT-Safe.
Not all libraries are now MT-Safe. The commonly used libraries that
are MT-Safe are listed in Table 6–3.
Additional libraries will eventually be modified to be MT-Safe.
Table 6–3 Some MT-Safe Libraries
Library
Comments
lib/libc
Interfaces that are not safe have thread-safe interfaces of the form *_r (often with different semantics)
lib/libdl_stubs
To support static switch compiling
lib/libintl
Internationalization
library
lib/libm
Math library compliant
with System V Interface Definition, Edition 3, X/Open and ANSI C
lib/libmalloc
Space-efficient memory allocation library; see malloc(3X)
lib/libmapmalloc
Alternative mmap(2)-based memory allocation library; see mapmalloc(3X)
lib/libnsl
The TLI interface, XDR, RPC clients
and servers, netdir, netselect and getXXbyYY interfaces are not safe, but have thread-safe interfaces of the form getXXbyYY_r
lib/libresolv
Thread-specific errno support
lib/libsocket
Socket library for making network connections
lib/libw
Wide character and wide string functions for supporting
multibyte locales
lib/straddr
Network name-to-address translation library
lib/libX11
X11 Windows library
routines
lib/libC
C++ runtime shared objects
Unsafe Libraries
Routines in libraries that are not guaranteed to be MT-Safe can safely
be called by multithreaded programs only when such calls are single threaded.
