Multithreaded Programming Guide
Chapter 6 Safe and Unsafe Interfaces
This chapter defines MT-safety levels for functions and libraries.
Thread Safety
Thread safety is the avoidance of data races—situations in which data are set to either correct or incorrect values, depending upon the order in which multiple threads access and modify the data.
When no sharing is intended, give each thread a private copy of the data. When sharing is important, provide explicit synchronization to make certain that the program behaves in a deterministic manner.
A procedure is thread safe when it is logically correct when executed simultaneously by several threads. At a practical level, it is convenient to recognize three levels of safety.
An unsafe procedure can be made thread safe and serializable by surrounding it with statements to lock and unlock a mutex. Example 6–1shows three simplified implementations of fputs(), initially thread unsafe.
Next is a serializable version of this routine with a single mutex protecting the procedure from concurrent execution problems. Actually, this is stronger synchronization than is usually necessary. When two threads are sending output to different files using fputs(), one need not wait for the other—the threads need synchronization only when they are sharing an output file.
The last version is MT-safe. It uses one lock for each file, allowing two threads to print to different files at the same time. So, a routine is MT-safe when it is thread safe and its execution does not negatively affect performance.
Example 6–1 Degrees of Thread Safety
/* not thread-safe */
fputs(const char *s, FILE *stream) {
    char *p;
    for (p=s; *p; p++)
        putc((int)*p, stream);
/* serializable */
    static mutex_t mut;
    char *p;
    mutex_lock(&m);
    for (p=s; *p; p++)
    mutex_unlock(&m);
/* MT-Safe */
mutex_t m[NFILE];
    static mutex_t mut;
    char *p;
    mutex_lock(&m[fileno(stream)]);
    for (p=s; *p; p++)
    mutex_unlock(&m[fileno(stream)]0;
MT Interface Safety Levels
The threads man pages, man(3THR), use the safety level categories listed in Table 6–1 to describe how well an interface supports threads (these categories are explained more fully in the Intro(3) reference manual page).
Table 6–1 Interface Safety Levels
Category
Description
Safe
This code can be called from a multithreaded application
Safe with exceptions
See the NOTES sections of these pages for a description of the exceptions.
Unsafe
This interface is not safe to use with multithreaded applications unless the application arranges for only one thread at a time to execute within the library.
MT-Safe
This interface is fully prepared for multithreaded access in that it is both safe and it supports some concurrency.
MT-Safe with exceptions
See the NOTES sections of these pages in the man(3THR): Library Routines for a list of the exceptions.
Async-Signal-Safe
This routine can safely be called from a signal handler. A thread that is executing an Async-Signal-Safe routine does not deadlock with itself when it is interrupted by a signal.
Fork1–Safe
This interface releases locks it has held whenever the Solaris fork1(2) or the POSIX fork(2) is called.
See the section 3 manual pages for the safety levels of library routines.
Some functions have purposely not been made safe for the following reasons.
Caution – Caution –
There is no way to be certain that a function with a name not ending in “_r” is MT-Safe other than by checking its reference manual page. Use of a function identified as not MT-Safe must be protected by a synchronizing device or by restriction to the initial thread.
Reentrant Functions for Unsafe Interfaces
For most functions with Unsafe interfaces, an MT-Safe version of the routine exists. The name of the new MT-Safe routine is always the name of the old Unsafe routine with “_r” appended. The Table 6–2 “_r” routines are supplied in the Solaris environment.
Table 6–2 Reentrant Functions
asctime_r(3c)
gethostbyname_r(3n)
getservbyname_r(3n)
ctermid_r(3s)
gethostent_r(3n)
getservbyport_r(3n)
ctime_r(3c)
getlogin_r(3c)
getservent_r(3n)
fgetgrent_r(3c)
getnetbyaddr_r(3n)
getspent_r(3c)
fgetpwent_r(3c)
getnetbyname_r(3n)
getspnam_r(3c)
fgetspent_r(3c)
getnetent_r(3n)
gmtime_r(3c)
gamma_r(3m)
getnetgrent_r(3n)
lgamma_r(3m)
getauclassent_r(3)
getprotobyname_r(3n)
localtime_r(3c)
getauclassnam_r(3)
getprotobynumber_r(3n)
nis_sperror_r(3n)
getauevent_r(3)
getprotoent_r(3n)
rand_r(3c)
getauevnam_r(3)
getpwent_r(3c)
readdir_r(3c)
getauevnum_r(3)
getpwnam_r(3c)
strtok_r(3c)
getgrent_r(3c)
getpwuid_r(3c)
tmpnam_r(3s)
getgrgid_r(3c)
getrpcbyname_r(3n)
ttyname_r(3c)
getgrnam_r(3c)
getrpcbynumber_r(3n)
gethostbyaddr_r(3n)
getrpcent_r(3n)
Async-Signal-Safe Functions
Functions that can safely be called from signal handlers are Async-Signal-Safe. The POSIX standard defines and lists Async-Signal-Safe functions (IEEE Std 1003.1-1990, 3.3.1.3 (3)(f), page 55). In addition to the POSIX Async-Signal-Safe functions, these three functions from the Solaris threads library are also Async- Signal-Safe.
MT Safety Levels for Libraries
All routines that can potentially be called by a thread from a multithreaded program should be MT-Safe.
This means that two or more activations of a routine must be able to correctly execute concurrently. So, every library interface that a multithreaded program uses must be MT-Safe.
Not all libraries are now MT-Safe. The commonly used libraries that are MT-Safe are listed in Table 6–3. Additional libraries will eventually be modified to be MT-Safe.
Table 6–3 Some MT-Safe Libraries
Library
Comments
lib/libc
Interfaces that are not safe have thread-safe interfaces of the form *_r (often with different semantics)
lib/libdl_stubs
To support static switch compiling
lib/libintl
Internationalization library
lib/libm
Math library compliant with System V Interface Definition, Edition 3, X/Open and ANSI C
lib/libmalloc
Space-efficient memory allocation library; see malloc(3X)
lib/libmapmalloc
Alternative mmap(2)-based memory allocation library; see mapmalloc(3X)
lib/libnsl
The TLI interface, XDR, RPC clients and servers, netdir, netselect and getXXbyYY interfaces are not safe, but have thread-safe interfaces of the form getXXbyYY_r
lib/libresolv
Thread-specific errno support
lib/libsocket
Socket library for making network connections
lib/libw
Wide character and wide string functions for supporting multibyte locales
lib/straddr
Network name-to-address translation library
lib/libX11
X11 Windows library routines
lib/libC
C++ runtime shared objects
Unsafe Libraries
Routines in libraries that are not guaranteed to be MT-Safe can safely be called by multithreaded programs only when such calls are single threaded.
