Table 1–1 introduces some of the terms used in this book.
Table 1–1 Multithreading Terms
Term |
Definition |
Process |
The UNIX environment (such as file descriptors, user ID, and so on) created with the fork(2) system call, which is set up to run a program. |
A sequence of instructions executed within the context of a process. |
pthreads (POSIX threads) |
A POSIX 1003.1c compliant threads interface. |
Solaris threads |
A Sun MicrosystemsTM threads interface that is not POSIX compliant. A predecessor of pthreads. |
Restricting access to a single thread. |
Allowing access to two or more threads. |
Threads managed by the threads library routines in user (as opposed to kernel) space. |
Threads in the kernel that execute kernel code and system calls (also called LWPs). |
A user-level thread that is permanently bound to one LWP. |
Unbound thread |
A user-level thread that is not necessarily bound to one LWP. |
Attribute object |
Contains opaque data types and related manipulation functions used to standardize some of the configurable aspects of POSIX threads, mutual exclusion locks (mutexes), and condition variables. |
Mutual exclusion locks |
Functions that lock and unlock access to shared data. |
Condition variables |
Functions that block threads until a change of state. |
Read-write locks |
Functions that allow multiple read-only access to shared data, but exclusive access for modification of that data. |
A memory-based synchronization mechanism. |
Parallelism |
A condition that arises when at least two threads are executing simultaneously. |
Concurrency |
A condition that exists when at least two threads are making progress. A more generalized form of parallelism that can include time-slicing as a form of virtual parallelism. |
