This chapter compares the Application Programming Interface (API) for Solaris and POSIX threads, and explains the Solaris features that are not found in POSIX threads.
The Solaris threads API and the pthreads API are two solutions to the same problem: building parallelism into application software. Although each API is complete in itself, you can safely mix Solaris threads functions and pthread functions in the same program.
The two APIs do not match exactly, however. Solaris threads supports functions that are not found in pthreads, and pthreads includes functions that are not supported in the Solaris interface. For those functions that do match, the associated arguments might not, although the information content is effectively the same.
By combining the two APIs, you can use features not found in one to enhance the other. Similarly, you can run applications using Solaris threads, exclusively, with applications using pthreads, exclusively, on the same system.
Solaris threads and pthreads are very similar in both API action and syntax. The major differences are listed in Table 8–1.
Table 8–1 Unique Solaris Threads and pthreads Features
Solaris Threads (libthread) |
POSIX Threads (libpthread) |
thr_ prefix for threads function names; sema_ prefix for semaphore function names |
pthread_ prefix for pthreads function names; sem_ prefix for semaphore function names |
Ability to create “daemon” threads |
Cancellation semantics |
Suspending and continuing a thread |
Scheduling policies |
The following table compares Solaris threads functions with pthreads functions. Note that even when Solaris threads and pthreads functions appear to be essentially the same, the arguments to the functions can differ.
When a comparable interface is not available either in pthreads or Solaris threads, a hyphen `-' appears in the column. Entries in the pthreads column that are followed by “POSIX 1003.4” or “POSIX.4” are part of the POSIX Realtime standard specification and are not part of pthreads.
Table 8–2 Solaris Threads and POSIX pthreads Comparison
pthreads (libpthread) |
thr_create() |
pthread_create() |
thr_exit() |
pthread_exit() |
thr_join() |
pthread_join() |
thr_yield() |
sched_yield() POSIX.4 |
thr_self() |
pthread_self() |
thr_kill() |
pthread_kill() |
thr_sigsetmask() |
pthread_sigmask() |
thr_setprio() |
pthread_setschedparam() |
thr_getprio() |
pthread_getschedparam() |
thr_setconcurrency() |
pthread_setconcurrency() |
thr_getconcurrency() |
pthread_getconcurrency() |
thr_suspend() |
thr_continue() |
thr_keycreate() |
pthread_key_create() |
pthread_key_delete() |
thr_setspecific() |
pthread_setspecific() |
thr_getspecific() |
pthread_getspecific() |
pthread_once() |
pthread_equal() |
pthread_cancel() |
pthread_testcancel() |
pthread_cleanup_push() |
pthread_cleanup_pop() |
pthread_setcanceltype() |
pthread_setcancelstate() |
mutex_lock() |
pthread_mutex_lock() |
mutex_unlock() |
pthread_mutex_unlock() |
mutex_trylock() |
pthread_mutex_trylock() |
mutex_init() |
pthread_mutex_init() |
mutex_destroy() |
pthread_mutex_destroy() |
cond_wait() |
pthread_cond_wait() |
cond_timedwait() |
pthread_cond_timedwait() |
cond_reltimedwait() |
pthread_cond_reltimedwait_np() |
cond_signal() |
pthread_cond_signal() |
cond_broadcast() |
pthread_cond_broadcast() |
cond_init() |
pthread_cond_init() |
cond_destroy() |
pthread_cond_destroy() |
rwlock_init() |
pthread_rwlock_init() |
rwlock_destroy() |
pthread_rwlock_destroy() |
rw_rdlock() |
pthread_rwlock_rdlock() |
rw_wrlock() |
pthread_rwlock_wrlock() |
rw_unlock() |
pthread_rwlock_unlock() |
rw_tryrdlock() |
pthread_rwlock_tryrdlock() |
rw_trywrlock() |
pthread_rwlock_trywrlock() |
pthread_rwlockattr_init() |
pthread_rwlockattr_destroy() |
pthread_rwlockattr_getpshared() |
pthread_rwlockattr_setpshared() |
sema_init() |
sem_init() POSIX 1003.4 |
sema_destroy() |
sem_destroy() POSIX 1003.4 |
sema_wait() |
sem_wait() POSIX 1003.4 |
sema_post() |
sem_post() POSIX 1003.4 |
sema_trywait() |
sem_trywait() POSIX 1003.4 |
fork1() |
fork() |
pthread_atfork() |
fork() (multiple thread copy) |
pthread_mutexattr_init() |
pthread_mutexattr_destroy() |
type argument in mutex_init() |
pthread_mutexattr_setpshared() |
pthread_mutexattr_getpshared() |
pthread_mutex_attr_settype() |
pthread_mutex_attr_gettype() |
pthread_condattr_init() |
pthread_condattr_destroy() |
type argument in cond_init() |
pthread_condattr_setpshared() |
pthread_condattr_getpshared() |
pthread_attr_init() |
pthread_attr_destroy() |
THR_BOUND flag in thr_create() |
pthread_attr_setscope() |
pthread_attr_getscope() |
pthread_attr_setguardsize() |
pthread_attr_getguardsize() |
stack_size argument in thr_create() |
pthread_attr_setstacksize() |
pthread_attr_getstacksize() |
stack_addr argument in thr_create() |
pthread_attr_setstackaddr() |
pthread_attr_getstackaddr() |
THR_DETACH flag in thr_create() |
pthread_attr_setdetachstate() |
pthread_attr_getdetachstate() |
pthread_attr_setschedparam() |
pthread_attr_getschedparam() |
pthread_attr_setinheritsched() |
pthread_attr_getinheritsched() |
pthread_attr_setsschedpolicy() |
pthread_attr_getschedpolicy() |
To use the Solaris threads functions described in this chapter, you must link with the Solaris threads library -lthread).
Where functionality is virtually the same for both Solaris threads and for pthreads, (even though the function names or arguments might differ), only a brief example consisting of the correct include file and the function prototype is presented. Where return values are not given for the Solaris threads functions, see the appropriate pages in man(3): Library Routines for the function return values.
For more information on Solaris related functions, see the related pthreads documentation for the similarly named function.
Where Solaris threads functions offer capabilities that are not available in pthreads, a full description of the functions is provided.
thr_suspend(3THR) immediately suspends the execution of the thread specified by target_thread. On successful return from thr_suspend(), the suspended thread is no longer executing.
Once a thread is suspended, subsequent calls to thr_suspend() have no effect. Signals cannot awaken the suspended thread; they remain pending until the thread resumes execution.
#include <thread.h> int thr_suspend(thread_t tid);
In the following synopsis, pthread_t
tid
as defined in pthreads is the same as thread_t
tid in Solaris threads. tid values
can be used interchangeably either by assignment or through the use of casts.
thread_t tid; /* tid from thr_create() */ /* pthreads equivalent of Solaris tid from thread created */ /* with pthread_create() */ pthread_t ptid; int ret; ret = thr_suspend(tid); /* using pthreads ID variable with a cast */ ret = thr_suspend((thread_t) ptid);
thr_suspend() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, thr_suspend() fails and returns the corresponding value.
thr_continue(3THR) resumes the execution of a suspended thread. Once a suspended thread is continued, subsequent calls to thr_continue() have no effect.
#include <thread.h> int thr_continue(thread_t tid);
A suspended thread will not be awakened by a signal. The signal stays pending until the execution of the thread is resumed by thr_continue().
pthread_t
tid as defined in
tid
in Solaris threads. tid values can be used interchangeably
thread_t tid; /* tid from thr_create()*/ /* pthreads equivalent of Solaris tid from thread created */ /* with pthread_create()*/ pthread_t ptid; int ret; ret = thr_continue(tid); /* using pthreads ID variable with a cast */ ret = thr_continue((thread_t) ptid)
thr_continue() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, thr_continue() fails and returns the corresponding value.
Read-write locks allow simultaneous read access by many threads while restricting write access to only one thread at a time.
When any thread holds the lock for reading, other threads can also acquire the lock for reading but must wait to acquire the lock for writing. If one thread holds the lock for writing, or is waiting to acquire the lock for writing, other threads must wait to acquire the lock for either reading or writing.
Read-write locks are slower than mutexes, but can improve performance when they protect data that are not frequently written but that are read by many concurrent threads.
Use read-write locks to synchronize threads in this process and other processes by allocating them in memory that is writable and shared among the cooperating processes (see mmap(2)) and by initializing them for this behavior.
By default, the acquisition order is not defined when multiple threads are waiting for a read-write lock. However, to avoid writer starvation, the Solaris threads package tends to favor writers over readers.
Read-write locks must be initialized before use.
#include <synch.h> (or #include <thread.h>) int rwlock_init(rwlock_t *rwlp, int type, void * arg);
Use rwlock_init(3THR) to initialize the read-write lock pointed to by rwlp and to set the lock state to unlocked. type can be one of the following (note that arg is currently ignored). (For POSIX threads, see pthread_rwlock_init(3THR).)
USYNC_PROCESS The read-write lock can be used to synchronize threads in this process and other processes. arg is ignored.
USYNC_THREAD The read-write lock can be used to synchronize threads in this process, only. arg is ignored.
Multiple threads must not initialize the same read-write lock simultaneously. Read-write locks can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed. A read-write lock must not be reinitialized while other threads might be using it.
#include <thread.h> rwlock_t rwlp; int ret; /* to be used within this process only */ ret = rwlock_init(&rwlp, USYNC_THREAD, 0);
#include <thread.h> rwlock_t rwlp; int ret; /* to be used among all processes */ ret = rwlock_init(&rwlp, USYNC_PROCESS, 0);
rwlock_init() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
#include <synch.h> (or #include <thread.h>) int rw_rdlock(rwlock_t *rwlp);
Use rw_rdlock(3THR) to acquire a read lock on the read-write lock pointed to by rwlp. When the read-write lock is already locked for writing, the calling thread blocks until the write lock is released. Otherwise, the read lock is acquired. (For POSIX threads, see pthread_rwlock_rdlock(3THR).)
rw_rdlock() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
#include <synch.h> (or #include <thread.h>) int rw_tryrdlock(rwlock_t *rwlp);
Use rw_tryrdlock(3THR) to attempt to acquire a read lock on the read-write lock pointed to by rwlp. When the read-write lock is already locked for writing, it returns an error. Otherwise, the read lock is acquired. (For POSIX threads, see pthread_rwlock_tryrdlock(3THR).)
rw_tryrdlock() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
#include <synch.h> (or #include <thread.h>) int rw_wrlock(rwlock_t *rwlp);
Use rw_wrlock(3THR) to acquire a write lock on the read-write lock pointed to by rwlp. When the read-write lock is already locked for reading or writing, the calling thread blocks until all the read locks and write locks are released. Only one thread at a time can hold a write lock on a read-write lock. (For POSIX threads, see pthread_rwlock_wrlock(3THR).)
rw_wrlock() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
#include <synch.h> (or #include <thread.h>) int rw_trywrlock(rwlock_t *rwlp);
Use rw_trywrlock(3THR) to attempt to acquire a write lock on the read-write lock pointed to by rwlp. When the read-write lock is already locked for reading or writing, it returns an error. (For POSIX threads, see pthread_rwlock_trywrlock(3THR).)
rw_trywrlock() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
#include <synch.h> (or #include <thread.h>) int rw_unlock(rwlock_t *rwlp);
Use rw_unlock(3THR) to unlock a read-write lock pointed to by rwlp. The read-write lock must be locked and the calling thread must hold the lock either for reading or writing. When any other threads are waiting for the read-write lock to become available, one of them is unblocked. (For POSIX threads, see pthread_rwlock_unlock(3THR).)
rw_unlock() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
EINVAL
Invalid argument.
EFAULT
rwlp points to an illegal address.
#include <synch.h> (or #include <thread.h>) int rwlock_destroy(rwlock_t *rwlp);
Use rwlock_destroy(3THR) to destroy any state associated with the read-write lock pointed to by rlwp. The space for storing the read-write lock is not freed. (For POSIX threads, see pthread_rwlock_destroy(3THR).)
rwlock_destroy() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
Example 8–1 uses a bank account to demonstrate read-write locks. While the program could allow multiple threads to have concurrent read-only access to the account balance, only a single writer is allowed. Note that the get_balance() function needs the lock to ensure that the addition of the checking and saving balances occurs atomically.
rwlock_t account_lock; float checking_balance = 100.0; float saving_balance = 100.0; ... rwlock_init(&account_lock, 0, NULL); ... float get_balance() { float bal; rw_rdlock(&account_lock); bal = checking_balance + saving_balance; rw_unlock(&account_lock); return(bal); } void transfer_checking_to_savings(float amount) { rw_wrlock(&account_lock); checking_balance = checking_balance - amount; saving_balance = saving_balance + amount; rw_unlock(&account_lock); }
Operation |
Destination Discussion |
Create a thread | |
Get the minimal stack size | |
Get the thread identifier | |
Yield thread execution | |
Send a signal to a thread | |
Access the signal mask of the calling thread | |
Terminate a thread | |
Wait for thread termination | |
Create a thread-specific data key | |
Set thread-specific data | |
Get thread-specific data | |
Set the thread priority | |
Get the thread priority |
The thr_create(3THR) routine is one of the most elaborate of all the Solaris threads library routines.
Usethr_create(3THR) to add a new thread of control to the current process. (For POSIX threads, see pthread_create(3THR).)
Note that the new thread does not inherit pending signals, but it does inherit priority and signal masks.
#include <thread.h> int thr_create(void *stack_base, size_t stack_size, void *(*start_routine) (void *), void *arg, long flags, thread_t *new_thread); size_t thr_min_stack(void);
stack_base—Contains the address for the stack that the new thread uses. If stack_base is NULL then thr_create() allocates a stack for the new thread with at least stack_size bytes.
stack_size—Contains the size, in number of bytes, for the stack that the new thread uses. If stack_size is zero, a default size is used. In most cases, a zero value works best. If stack_size is not zero, it must be greater than the value returned by thr_min_stack().
There is no general need to allocate stack space for threads. The threads library allocates 1 megabyte of virtual memory for each thread's stack with no swap space reserved. (The library uses the -MAP_NORESERVE option of mmap(2) to make the allocations.)
start_routine—Contains the function with which the new thread begins execution. When start_routine() returns, the thread exits with the exit status set to the value returned by start_routine (see thr_exit(3THR)).
arg—Can be anything that is described by void, which is typically any 4-byte value. Anything larger must be passed indirectly by having the argument point to it.
Note that you can supply only one argument. To get your procedure to take multiple arguments, encode them as one (such as by putting them in a structure).
flags—Specifies attributes for the created thread. In most cases a zero value works best.
The value in flags is constructed from the bitwise inclusive OR of the following:
THR_SUSPENDED—Suspends the new thread and does not execute start_routine until the thread is started by thr_continue(). Use this to operate on the thread (such as changing its priority) before you run it. The termination of a detached thread is ignored.
THR_DETACHED—Detaches the new thread so that its thread ID and other resources can be reused as soon as the thread terminates. Set this when you do not want to wait for the thread to terminate.
When there is no explicit synchronization to prevent it, an unsuspended, detached thread can die and have its thread ID reassigned to another new thread before its creator returns from thr_create().
THR_DAEMON—Marks the new thread as a daemon. A daemon thread is always detached (THR_DAEMON implies THR_DETACHED). The process exits when all nondaemon threads exit. Daemon threads do not affect the process exit status and are ignored when counting the number of thread exits.
A process can exit either by calling exit() or by having every thread in the process that was not created with the THR_DAEMON flag call thr_exit(3THR). An application, or a library it calls, can create one or more threads that should be ignored (not counted) in the decision of whether to exit. The THR_DAEMON flag identifies threads that are not counted in the process exit criterion.
new_thread—Points to a location (when new_thread is not NULL) where the ID of the new thread is stored when thr_create() is successful. The caller is responsible for supplying the storage this argument points to. The ID is valid only within the calling process.
If you are not interested in this identifier, supply a NULL value to new_thread.
thr_create() returns zero when it completes successfully. Any other return value indicates that an error occurred. When any of the following conditions is detected, thr_create() fails and returns the corresponding value.
Stack behavior in Solaris threads is generally the same as that in pthreads. For more information about stack setup and operation, see About Stacks.
You can get the absolute minimum on stack size by calling thr_min_stack(), which returns the amount of stack space required for a thread that executes a null procedure. Useful threads need more than this, so be very careful when reducing the stack size.
You can specify a custom stack in two ways. The first is to supply a NULL for the stack location, thereby asking the runtime library to allocate the space for the stack, but to supply the desired size in the stacksize parameter to thr_create().
The other approach is to take overall aspects of stack management and supply a pointer to the stack to thr_create(). This means that you are responsible not only for stack allocation but also for stack deallocation—when the thread terminates, you must arrange for the disposal of its stack.
When you allocate your own stack, be sure to append a red zone to its end by calling mprotect(2).
Use thr_min_stack(3THR) to get the minimum stack size for a thread.
#include <thread.h> size_t thr_min_stack(void);
thr_min_stack() returns the amount of space needed to execute a null thread (a null thread is a thread that is created to execute a null procedure).
A thread that does more than execute a null procedure should allocate a stack size greater than the size of thr_min_stack().
When a thread is created with a user-supplied stack, the user must reserve enough space to run the thread. In a dynamically linked execution environment, it is difficult to know what the thread minimal stack requirements are.
Most users should not create threads with user-supplied stacks. User-supplied stacks exist only to support applications that require complete control over their execution environments.
Instead, users should let the threads library manage stack allocation. The threads library provides default stacks that should meet the requirements of any created thread.
Use thr_self(3THR) to get the ID of the calling thread. (For POSIX threads, see pthread_self(3THR).)
#include <thread.h> thread_t thr_self(void);
thr_yield(3THR) causes the current thread to yield its execution in favor of another thread with the same or greater priority; otherwise it has no effect. There is no guarantee that a thread calling thr_yield() will do so.
#include <thread.h> void thr_yield(void);
thr_kill(3THR) sends a signal to a thread. (For POSIX threads, see pthread_kill(3THR).)
#include <thread.h> #include <signal.h> int thr_kill(thread_t target_thread, int sig);
Use thr_sigsetmask(3THR) to change or examine the signal mask of the calling thread.
#include <thread.h> #include <signal.h> int thr_sigsetmask(int how, const sigset_t *set, sigset_t *oset);
Use thr_exit(3THR) to terminate a thread. (For POSIX threads, see pthread_exit(3THR).)
#include <thread.h> void thr_exit(void *status);
Use thr_join(3THR) to wait for a thread to terminate. (For POSIX threads, see pthread_join(3THR).)
#include <thread.h> int thr_join(thread_t tid, thread_t *departedid, void **status);
#include <thread.h> thread_t tid; thread_t departedid; int ret; void *status; /* waiting to join thread "tid" with status */ ret = thr_join(tid, &departedid, &status); /* waiting to join thread "tid" without status */ ret = thr_join(tid, &departedid, NULL); /* waiting to join thread "tid" without return id and status */ ret = thr_join(tid, NULL, NULL);
When the tid is (thread_t)0
, then thread_join() waits for any undetached thread in the process to terminate.
In other words, when no thread identifier is specified, any undetached thread
that exits causes thread_join() to return.
#include <thread.h> thread_t tid; thread_t departedid; int ret; void *status; /* waiting to join any non-detached thread with status */ ret = thr_join(0, &departedid, &status);
By indicating 0 as the thread id in the Solaris thr_join(), a join will take place when any non detached thread in the process exits. The departedid will indicate the thread ID of the exiting thread.
Except for the function names and arguments, thread specific data is the same for Solaris as it is for POSIX. The synopses for the Solaris functions are given in this section.
thr_keycreate(3THR) allocates a key that is used to identify thread-specific data in a process. (For POSIX threads, see pthread_key_create(3THR).)
#include <thread.h> int thr_keycreate(thread_key_t *keyp, void (*destructor) (void *value));
thr_setspecific(3THR) binds value to the thread-specific data key, key, for the calling thread. (For POSIX threads, see pthread_setspecific(3THR).)
#include <thread.h> int thr_setspecific(thread_key_t key, void *value);
thr_getspecific(3THR) stores the current value bound to key for the calling thread into the location pointed to by valuep. (For POSIX threads, see pthread_getspecific(3THR).)
#include <thread.h> int thr_getspecific(thread_key_t key, void **valuep);
In Solaris threads, if a thread is to be created with a priority other than that of its parent's, it is created in SUSPEND mode. While suspended, the threads priority is modified using the thr_setprio(3THR) function call; then it is continued.
A higher priority thread will receive precedence by libthread over lower priority threads with respect to synchronization object contention.
thr_setprio(3THR) changes the priority of the thread, specified by tid, within the current process to the priority specified by newprio. (For POSIX threads, see pthread_setschedparam(3THR).)
#include <thread.h> int thr_setprio(thread_t tid, int newprio)
By default, threads are scheduled based on fixed priorities that range from zero, the least significant, to 127 the most significant.
thread_t tid; int ret; int newprio = 20; /* suspended thread creation */ ret = thr_create(NULL, NULL, func, arg, THR_SUSPENDED, &tid); /* set the new priority of suspended child thread */ ret = thr_setprio(tid, newprio); /* suspended child thread starts executing with new priority */ ret = thr_continue(tid);
Use thr_getprio(3THR) to get the current priority for the thread. Each thread inherits a priority from its creator. thr_getprio() stores the current priority, tid, in the location pointed to by newprio. (For POSIX threads, see pthread_getschedparam(3THR).)
#include <thread.h> int thr_getprio(thread_t tid, int *newprio)
#include <synch.h> #include <thread.h> int mutex_init(mutex_t *mp, int type, void *arg));
Use mutex_init(3THR) to initialize the mutex pointed to by mp. The type can be one of the following (note that arg is currently ignored). (For POSIX threads, see Initialize a Mutex.)
USYNC_PROCESS_ROBUST The mutex can be used to robustly synchronize threads in this and other processes.
When a process dies while holding a USYNC_PROCESS lock, subsequent requestors of that lock hang. This is a problem for systems which share locks with client processes because the client processes can be abnormally killed. To avoid the problem of hanging on a lock held by a dead process, use USYNC_PROCESS_ROBUST to lock the mutex. USYNC_PROCESS_ROBUST adds two capabilities:
In the case of process death, all owned locks held by that process are unlocked.
The next requestor for any of the locks owned by the dead process receives the lock, but with an error return indicating that the previous owner died while holding the lock..
Mutexes can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed.
Multiple threads must not initialize the same mutex simultaneously. A mutex lock must not be reinitialized while other threads might be using it.
#include <thread.h> mutex_t mp; int ret; /* to be used within this process only */ ret = mutex_init(&mp, USYNC_THREAD, 0);
#include <thread.h> mutex_t mp; int ret; /* to be used among all processes */ ret = mutex_init(&mp, USYNC_PROCESS, 0);
#include <thread.h> mutex_t mp; int ret; /* to be used among all processes */ ret = mutex_init(&mp, USYNC_PROCESS_ROBUST, 0);
#include <thread.h> int mutex_destroy (mutex_t *mp);
Use mutex_destroy(3THR) to destroy any state associated with the mutex pointed to by mp. Note that the space for storing the mutex is not freed. (For POSIX threads, see pthread_mutex_destroy(3THR).)
#include <thread.h> int mutex_lock(mutex_t *mp);
Use mutex_lock(3THR) to lock the mutex pointed to by mp. When the mutex is already locked, the calling thread blocks until the mutex becomes available (blocked threads wait on a prioritized queue). (For POSIX threads, see pthread_mutex_lock(3THR).)
#include <thread.h> int mutex_unlock(mutex_t *mp);
Use mutex_unlock(3THR) to unlock the mutex pointed to by mp. The mutex must be locked and the calling thread must be the one that last locked the mutex (the owner). (For POSIX threads, see pthread_mutex_unlock(3THR).)
#include <thread.h> int mutex_trylock(mutex_t *mp);
Use mutex_trylock(3THR) to attempt to lock the mutex pointed to by mp. This function is a nonblocking version of mutex_lock(). (For POSIX threads, see pthread_mutex_trylock(3THR).)
#include <thread.h> int cond_init(cond_t *cv, int type, int arg);
Use cond_init(3THR) to initialize the condition variable pointed to by cv. The type can be one of the following (note that arg is currently ignored). (For POSIX threads, see pthread_condattr_init(3THR).)
USYNC_PROCESS The condition variable can be used to synchronize threads in this and other processes. arg is ignored.
USYNC_THREAD The condition variable can be used to synchronize threads in this process only. arg is ignored.
Condition variables can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed.
Multiple threads must not initialize the same condition variable simultaneously. A condition variable must not be reinitialized while other threads might be using it.
#include <thread.h> cond_t cv; int ret; /* to be used within this process only */ ret = cond_init(cv, USYNC_THREAD, 0);
#include <thread.h> cond_t cv; int ret; /* to be used among all processes */ ret = cond_init(&cv, USYNC_PROCESS, 0);
#include <thread.h> int cond_destroy(cond_t *cv);
Use cond_destroy(3THR) to destroy state associated with the condition variable pointed to by cv. The space for storing the condition variable is not freed. (For POSIX threads, see pthread_condattr_destroy(3THR).)
#include <thread.h> int cond_wait(cond_t *cv, mutex_t *mp);
Use cond_wait(3THR) to atomically release the mutex pointed to by mp and to cause the calling thread to block on the condition variable pointed to by cv. The blocked thread can be awakened by cond_signal(), cond_broadcast(), or when interrupted by delivery of a signal or a fork(). (For POSIX threads, see pthread_cond_wait(3THR).)
#include <thread.h> int cond_timedwait(cond_t *cv, mutex_t *mp, timestruct_t abstime);
Use cond_timedwait(3THR) as you would use cond_wait(), except that cond_timedwait() does not block past the time of day specified by abstime. (For POSIX threads, see pthread_cond_timedwait(3THR).)
cond_timedwait() always returns with the mutex locked and owned by the calling thread even when returning an error.
The cond_timedwait() function blocks until the condition is signaled or until the time of day specified by the last argument has passed. The timeout is specified as the time of day so the condition can be retested efficiently without recomputing the time-out value.
#include <thread.h> int cond_reltimedwait(cond_t *cv, mutex_t *mp, timestruct_t reltime);
Use cond_reltimedwait(3THR) as you would use cond_timedwait(), except that cond_reltimedwait() takes a relative time interval value in its third argument rather than an absolute time of day value. (For POSIX threads see, pthread_cond_reltimedwait_np(3THR).
cond_reltimedwait() always returns with the mutex locked and owned by the calling thread even when returning an error. The cond_reltimedwait() function blocks until the condition is signaled or until the time interval specified by the last argument has elapsed.
#include <thread.h> int cond_signal(cond_t *cv);
Use cond_signal(3THR) to unblock one thread that is blocked on the condition variable pointed to by cv. Call this function under protection of the same mutex used with the condition variable being signaled. Otherwise, the condition could be signaled between its test and cond_wait(), causing an infinite wait.
#include <thread.h> int cond_broadcast(cond_t *cv);
Use cond_broadcast(3THR) to unblock all threads that are blocked on the condition variable pointed to by cv. When no threads are blocked on the condition variable then cond_broadcast() has no effect.
Semaphore operations are the same in both the Solaris Operating Environment and the POSIX environment. The function name changed from sema_ in the Solaris Operating Environment to sem_ in pthreads.
#include <thread.h> int sema_init(sema_t *sp, unsigned int count, int type, void *arg);
Use sema_init(3THR) to initialize the semaphore variable pointed to by sp by count amount. type can be one of the following (note that arg is currently ignored).
USYNC_PROCESS The semaphore can be used to synchronize threads in this process and other processes. Only one process should initialize the semaphore. arg is ignored.
USYNC_THREAD The semaphore can be used to synchronize threads in this process, only. arg is ignored.
Multiple threads must not initialize the same semaphore simultaneously. A semaphore must not be reinitialized while other threads might be using it.
#include <thread.h> sema_t sp; int ret; int count; count = 4; /* to be used within this process only */ ret = sema_init(&sp, count, USYNC_THREAD, 0);
#include <thread.h> sema_t sp; int ret; int count; count = 4; /* to be used among all the processes */ ret = sema_init (&sp, count, USYNC_PROCESS, 0);
#include <thread.h> int sema_post(sema_t *sp);
Use sema_post(3THR) to atomically increment the semaphore pointed to by sp. When any threads are blocked on the semaphore, one is unblocked.
#include <thread.h> int sema_wait(sema_t *sp);
Use sema_wait(3THR) to block the calling thread until the count in the semaphore pointed to by sp becomes greater than zero, then atomically decrement it.
#include <thread.h> int sema_trywait(sema_t *sp);
Use sema_trywait(3THR) to atomically decrement the count in the semaphore pointed to by sp when the count is greater than zero. This function is a nonblocking version of sema_wait().
#include <thread.h> int sema_destroy(sema_t *sp);
Use sem_destroy(3THR) to destroy any state associated with the semaphore pointed to by sp. The space for storing the semaphore is not freed.
Each of the synchronization primitives can be set up to be used across process boundaries. This is done quite simply by ensuring that the synchronization variable is located in a shared memory segment and by calling the appropriate init routine with type set to USYNC_PROCESS.
If this has been done, then the operations on the synchronization variables work just as they do when type is USYNC_THREAD.
mutex_init(&m, USYNC_PROCESS, 0); rwlock_init(&rw, USYNC_PROCESS, 0); cond_init(&cv, USYNC_PROCESS, 0); sema_init(&s, count, USYNC_PROCESS, 0);
Using locks and condition variables between processes does not require using the threads library. The recommended approach is to use the threads library interfaces, but when this is not desirable, then the _lwp_mutex_* and _lwp_cond_* interfaces can be used as follows:
Allocate the locks and condition variables as usual in shared memory (either with shmop(2) or mmap(2)).
Then initialize the newly allocated objects appropriately with the USYNC_PROCESS type. Because no interface is available to perform the initialization (_lwp_mutex_init(2) and _lwp_cond_init(2) do not exist), the objects can be initialized using statically allocated and initialized dummy objects.
For example, to initialize lockp:
lwp_mutex_t *lwp_lockp; lwp_mutex_t dummy_shared_mutex = SHAREDMUTEX; /* SHAREDMUTEX is defined in /usr/include/synch.h */ ... ... lwp_lockp = alloc_shared_lock(); *lwp_lockp = dummy_shared_mutex;
Similarly, for condition variables:
lwp_cond_t *lwp_condp; lwp_cond_t dummy_shared_cv = SHAREDCV; /* SHAREDCV is defined in /usr/include/synch.h */ ... ... lwp_condp = alloc_shared_cv(); *lwp_condp = dummy_shared_cv;
Example 8–2 shows the producer/consumer problem with the producer and consumer in separate processes. The main routine maps zero-filled memory (that it shares with its child process) into its address space. Note that mutex_init() and cond_init() must be called because the type of the synchronization variables is USYNC_PROCESS.
A child process is created that runs the consumer. The parent runs the producer.
This example also shows the drivers for the producer and consumer. The producer_driver() simply reads characters from stdin and calls producer(). The consumer_driver() gets characters by calling consumer() and writes them to stdout.
The data structure for Example 8–2 is the same as that used for the solution with condition variables (see Nested Locking With a Singly Linked List).
main() { int zfd; buffer_t *buffer; zfd = open(“/dev/zero”, O_RDWR); buffer = (buffer_t *)mmap(NULL, sizeof(buffer_t), PROT_READ|PROT_WRITE, MAP_SHARED, zfd, 0); buffer->occupied = buffer->nextin = buffer->nextout = 0; mutex_init(&buffer->lock, USYNC_PROCESS, 0); cond_init(&buffer->less, USYNC_PROCESS, 0); cond_init(&buffer->more, USYNC_PROCESS, 0); if (fork() == 0) consumer_driver(buffer); else producer_driver(buffer); } void producer_driver(buffer_t *b) { int item; while (1) { item = getchar(); if (item == EOF) { producer(b, `\0'); break; } else producer(b, (char)item); } } void consumer_driver(buffer_t *b) { char item; while (1) { if ((item = consumer(b)) == '\0') break; putchar(item); } }
A child process is created to run the consumer; the parent runs the producer.
Solaris threads and POSIX threads define the behavior of fork() differently. See Process Creation—exec(2) and exit(2) Issues for a thorough discussion of fork() issues.
Solaris libthread supports both fork() and fork1(). The fork() call has “fork-all” semantics—it duplicates everything in the process, including threads and LWPs, creating a true clone of the parent. The fork1() call creates a clone that has only one thread; the process state and address space are duplicated, but only the calling thread is cloned.
POSIX libpthread supports only fork(), which has the same semantics as fork1() in Solaris threads.
Whether fork() has “fork-all” semantics or “fork-one” semantics is dependent on which library is used. Linking with -lthread assigns “fork-all” semantics to fork(), while linking with -lpthread assigns “fork-one” semantics to fork().
See Linking With libthread or libpthread for more details.
