Multithreaded Programming Guide
mutex_init(3THR)
#include <synch.h>
#include <thread.h>
int mutex_init(mutex_t *mp, int type, void *arg));
Use mutex_init(3THR) to initialize the mutex pointed to by mp. The type can be one of the following (note that arg is currently ignored). (For POSIX threads, see Initialize a Mutex.)
When a process dies while holding a USYNC_PROCESS lock, subsequent requestors of that lock hang. This is a problem for systems which share locks with client processes because the client processes can be abnormally killed. To avoid the problem of hanging on a lock held by a dead process, use USYNC_PROCESS_ROBUST to lock the mutex. USYNC_PROCESS_ROBUST adds two capabilities:
Mutexes can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed.
Multiple threads must not initialize the same mutex simultaneously. A mutex lock must not be reinitialized while other threads might be using it.
Mutexes With Intraprocess Scope
#include <thread.h>
mutex_t mp;
int ret;
/* to be used within this process only */
ret = mutex_init(&mp, USYNC_THREAD, 0);
Mutexes With Interprocess Scope
#include <thread.h>
mutex_t mp;
int ret;
/* to be used among all processes */
ret = mutex_init(&mp, USYNC_PROCESS, 0);
Mutexes With Interprocess Scope-Robust
#include <thread.h>
mutex_t mp;
int ret;
ret = mutex_init(&mp, USYNC_PROCESS_ROBUST, 0);
