Multithreaded Programming Guide
thr_continue(3THR)
thr_continue(3THR) resumes the execution of a suspended thread. Once a suspended thread is continued, subsequent calls to thr_continue() have no effect.
#include <thread.h>
int thr_continue(thread_t tid);
A suspended thread will not be awakened by a signal. The signal stays pending until the execution of the thread is resumed by thr_continue().
pthread_t tid as defined in pthreads is the same as thread_t tid in Solaris threads. tid values can be used interchangeably either by assignment or through the use of casts.
thread_t tid; /* tid from thr_create()*/
/* pthreads equivalent of Solaris tid from thread created */
/* with pthread_create()*/
pthread_t ptid;
int ret;
ret = thr_continue(tid);
/* using pthreads ID variable with a cast */
ret = thr_continue((thread_t) ptid)
Return Values
thr_continue() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, thr_continue() fails and returns the corresponding value.
ESRCH
tid cannot be found in the current process.
