Use pthread_setschedparam(3THR) to modify the priority of an existing thread. This function has no effect on scheduling policy.
Prototype:
int pthread_setschedparam(pthread_t tid, int policy,
const struct sched_param *param);
#include <pthread.h> pthread_t tid; int ret; struct sched_param param; int priority; /* sched_priority will be the priority of the thread */ sched_param.sched_priority = priority; /* only supported policy, others will result in ENOTSUP */ policy = SCHED_OTHER; /* scheduling parameters of target thread */ ret = pthread_setschedparam(tid, policy, ¶m);
pthread_setschedparam() returns zero after completing successfully. Any other return value indicates that an error occurred. When either of the following conditions occurs, the pthread_setschedparam() function fails and returns the corresponding value.
