Multithreaded Programming Guide
The Threads Library
This chapter introduces the basic threads programming routines from the POSIX threads library, libpthread(3THR). This chapter covers default threads, or threads with default attribute values, which are the kind of threads that are most often used in multithreaded programming.
Chapter 3, Thread Create Attributes, explains how to create and use threads with nondefault attributes.
The POSIX (libpthread) routines introduced here have programming interfaces that are similar to the original (libthread) Solaris multithreading library.
The following brief roadmap directs you to the discussion of a particular task and its associated man page.
Create a Default Thread
When an attribute object is not specified, it is NULL, and the default thread is created with the following attributes:
You can also create a default attribute object with pthread_attr_init(), and then use this attribute object to create a default thread. See the section Initialize Attributesfor details.
pthread_create(3THR)
Use pthread_create(3THR) to add a new thread of control to the current process.
Prototype:
int	pthread_create(pthread_t *tid, const pthread_attr_t *tattr,
    void*(*start_routine)(void *), void *arg);
#include <pthread.h>
pthread_attr_t ()tattr;
pthread_t tid;
extern void *start_routine(void *arg);
void *arg;
int ret;
/* default behavior*/
ret = pthread_create(&tid, NULL, start_routine, arg);
/* initialized with default attributes */
ret = pthread_attr_init(&tattr);
/* default behavior specified*/
ret = pthread_create(&tid, &tattr, start_routine, arg);
The pthread_create() function is called with attr having the necessary state behavior. start_routine is the function with which the new thread begins execution. When start_routine returns, the thread exits with the exit status set to the value returned by start_routine (see pthread_create(3THR)).
When pthread_create() is successful, the ID of the thread created is stored in the location referred to as tid.
Creating a thread using a NULL attribute argument has the same effect as using a default attribute; both create a default thread. When tattr is initialized, it acquires the default behavior.
Return Values
pthread_create() returns zero when it completes successfully. Any other return value indicates that an error occurred. When any of the following conditions are detected, pthread_create() fails and returns the corresponding value.
EAGAIN
A system limit is exceeded, such as when too many LWPs have been created.
EINVAL
The value of tattr is invalid.
Wait for Thread Termination
pthread_join(3THR)
Use pthread_join(3THR) to wait for a thread to terminate.
Prototype:
int	pthread_join(thread_t tid, void **status);
pthread_t tid;
int ret;
void *status;
/* waiting to join thread "tid" with status */
ret = pthread_join(tid, &status);
/* waiting to join thread "tid" without status */
ret = pthread_join(tid, NULL);
The pthread_join() function blocks the calling thread until the specified thread terminates.
The specified thread must be in the current process and must not be detached. For information on thread detachment, see Set Detach State.
When status is not NULL, it points to a location that is set to the exit status of the terminated thread when pthread_join() returns successfully.
If multiple threads wait for the same thread to terminate, they all wait until the target thread terminates, than one thread returns successfully and the others fail with an error of ESRCH.
After pthread_join() returns, any data storage associated with the thread can be reclaimed by the application.
Return Values
pthread_join() returns zero when it completes successfully. Any other return value indicates that an error occurred. When any of the following conditions are detected, pthread_join() fails and returns the corresponding value.
ESRCH
tid is not a valid, undetached thread in the current process.
EDEADLK
A deadlock would exist, such as a thread waits for itself or thread A waits for thread B and thread B waits for thread A.
EINVAL
The value of tid is invalid.
Remember that pthread_join() works only for target threads that are nondetached. When there is no reason to synchronize with the termination of a particular thread, then that thread should be detached.
A Simple Threads Example
In Example 2–1, one thread executes the procedure at the top, creating a helper thread that executes the procedure fetch(), which involves a complicated database lookup and might take some time.
The main thread wants the results of the lookup but has other work to do in the meantime. So it does those other things and then waits for its helper to complete its job by executing pthread_join().
An argument, pbe, to the new thread is passed as a stack parameter. This can be done here because the main thread waits for the spun-off thread to terminate. In general, though, it is better to use malloc(3C) to allocate storage from the heap instead of passing an address to thread stack storage, because this address might disappear or be reassigned if the thread terminated.
Example 2–1 A Simple Threads Program
void mainline (...)
        struct phonebookentry *pbe;
        pthread_attr_t tattr;
        pthread_t helper;
        void *status;
        pthread_create(&helper, NULL, fetch, &pbe);
            /* do something else for a while */
        pthread_join(helper, &status);
        /* it's now safe to use result */
void *fetch(struct phonebookentry *arg)
        struct phonebookentry *npbe;
        /* fetch value from a database */
        npbe = search (prog_name)
            if (npbe != NULL)
                *arg = *npbe;
        pthread_exit(0);
struct phonebookentry {
        char name[64];
        char phonenumber[32];
        char flags[16];
Detaching a Thread
pthread_detach(3THR)
pthread_detach(3THR) is an alternative to pthread_join(3THR) to reclaim storage for a thread that is created with a detachstate attribute set to PTHREAD_CREATE_JOINABLE.
Prototype:
int	pthread_detach(thread_t tid);
pthread_t tid;
int ret;
/* detach thread tid */
ret = pthread_detach(tid);
The pthread_detach() function is used to indicate to the implementation that storage for the thread tid can be reclaimed when the thread terminates. If tid has not terminated, pthread_detach() does not cause it to terminate. The effect of multiple pthread_detach() calls on the same target thread is unspecified.
Return Values
pthread_detach() returns zero when it completes successfully. Any other return value indicates that an error occurred. When any of the following conditions is detected, pthread_detach() fails and returns the corresponding value.
EINVAL
tid is not a valid thread.
ESRCH
Create a Key for Thread-Specific Data
Single-threaded C programs have two basic classes of data—local data and global data. For multithreaded C programs a third class is added—thread-specific data (TSD). This is very much like global data, except that it is private to a thread.
Thread-specific data is maintained on a per-thread basis. TSD is the only way to define and refer to data that is private to a thread. Each thread-specific data item is associated with a key that is global to all threads in the process. Using the key, a thread can access a pointer (void *) that is maintained per-thread.
pthread_key_create(3THR)
Use pthread_key_create(3THR) to allocate a key that is used to identify thread-specific data in a process. The key is global to all threads in the process, and all threads initially have the value NULL associated with the key when it is created.
Call pthread_key_create() once for each key before using the key. There is no implicit synchronization.
Once a key has been created, each thread can bind a value to the key. The values are specific to the threads and are maintained for each thread independently. The per-thread binding is deallocated when a thread terminates if the key was created with a destructor function.
Prototype:
int	pthread_key_create(pthread_key_t *key,
    void (*destructor) (void *));
pthread_key_t key;
int ret;
/* key create without destructor */
ret = pthread_key_create(&key, NULL);
/* key create with destructor */
ret = pthread_key_create(&key, destructor);
When pthread_key_create() returns successfully, the allocated key is stored in the location pointed to by key. The caller must ensure that the storage and access to this key are properly synchronized.
An optional destructor function, destructor, can be used to free stale storage. When a key has a non-NULL destructor function and the thread has a non-NULL value associated with that key, the destructor function is called with the current associated value when the thread exits. The order in which the destructor functions are called is unspecified.
Return Values
pthread_key_create() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occur, pthread_key_create() fails and returns the corresponding value.
EAGAIN
The key name space is exhausted.
ENOMEM
Not enough virtual memory is available in this process to create a new key.
Delete the Thread-Specific Data Key
pthread_key_delete(3THR)
Use pthread_key_delete(3THR) to destroy an existing thread-specific data key. Any memory associated with the key can be freed because the key has been invalidated and will return an error if ever referenced. There is no comparable function in Solaris threads.
Prototype:
int	pthread_key_delete(pthread_key_t key);
pthread_key_t key;
int ret;
/* key previously created */
ret = pthread_key_delete(key);
Once a key has been deleted, any reference to it with the pthread_setspecific() or pthread_getspecific() call yields undefined results.
It is the responsibility of the programmer to free any thread-specific resources before calling the delete function. This function does not invoke any of the destructors.
Return Values
pthread_key_delete() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, pthread_key_create() fails and returns the corresponding value.
EINVAL
The key value is invalid.
Set Thread-Specific Data
pthread_setspecific(3THR)
Use pthread_setspecific(3THR) to set the thread-specific binding to the specified thread-specific data key.
Prototype:
int	pthread_setspecific(pthread_key_t key, const void *value);
pthread_key_t key;
void *value;
int ret;
ret = pthread_setspecific(key, value);
Return Values
pthread_setspecific() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occur, pthread_setspecific() fails and returns the corresponding value.
ENOMEM
Not enough virtual memory is available.
EINVAL
key is invalid.
Note –
pthread_setspecific() does not free its storage. If a new binding is set, the existing binding must be freed; otherwise, a memory leak can occur.
Get Thread-Specific Data
pthread_getspecific(3THR)
Use pthread_getspecific(3THR) to get the calling thread's binding for key, and store it in the location pointed to by value.
Prototype:
void	*pthread_getspecific(pthread_key_t key);
pthread_key_t key;
void *value;
value = pthread_getspecific(key);
Return Values
No errors are returned.
Global and Private Thread-Specific Data Example
Example 2–2shows an excerpt from a multithreaded program. This code is executed by any number of threads, but it has references to two global variables, errno and mywindow, that really should be references to items private to each thread.
Example 2–2 Thread-Specific Data—Global but Private
body() {
    while (write(fd, buffer, size) == -1) {
        if (errno != EINTR) {
            fprintf(mywindow, "%s\n", strerror(errno));
            exit(1);
References to errno should get the system error code from the routine called by this thread, not by some other thread. So, references to errno by one thread refer to a different storage location than references to errno by other threads.
The mywindow variable is intended to refer to a stdio stream connected to a window that is private to the referring thread. So, as with errno, references to mywindow by one thread should refer to a different storage location (and, ultimately, a different window) than references to mywindow by other threads. The only difference here is that the threads library takes care of errno, but the programmer must somehow make this work for mywindow.
The next example shows how the references to mywindow work. The preprocessor converts references to mywindow into invocations of the _mywindow() procedure.
This routine in turn invokes pthread_getspecific(), passing it the mywindow_key global variable (it really is a global variable) and an output parameter, win, that receives the identity of this thread's window.
Example 2–3 Turning Global References Into Private References
thread_key_t mywin_key;
FILE *_mywindow(void) {
    FILE *win;
    win = pthread_getspecific(mywin_key);
    return(win);
#define mywindow _mywindow()
void routine_uses_win( FILE *win) {
void thread_start(...) {
    make_mywin();
    routine_uses_win( mywindow )
The mywin_key variable identifies a class of variables for which each thread has its own private copy; that is, these variables are thread-specific data. Each thread calls make_mywin() to initialize its window and to arrange for its instance of mywindow to refer to it.
Once this routine is called, the thread can safely refer to mywindow and, after _mywindow(), the thread gets the reference to its private window. So, references to mywindow behave as if they were direct references to data private to the thread.
Example 2–4 shows how to set this up.
Example 2–4 Initializing the Thread-Specific Data
void make_mywindow(void) {
    FILE **win;
    static pthread_once_t mykeycreated = PTHREAD_ONCE_INIT;
    pthread_once(&mykeycreated, mykeycreate);
    win = malloc(sizeof(*win));
    create_window(win, ...);
    pthread_setspecific(mywindow_key, win);
void mykeycreate(void) {
    pthread_key_create(&mywindow_key, free_key);
void free_key(void *win) {
    free(win);
First, get a unique value for the key, mywin_key. This key is used to identify the thread-specific class of data. So, the first thread to call make_mywin() eventually calls pthread_key_create(), which assigns to its first argument a unique key. The second argument is a destructor function that is used to deallocate a thread's instance of this thread-specific data item once the thread terminates.
The next step is to allocate the storage for the caller's instance of this thread-specific data item. Having allocated the storage, a call is made to the create_window() routine, which sets up a window for the thread and sets the storage pointed to by win to refer to it. Finally, a call is made to pthread_setspecific(), which associates the value contained in win (that is, the location of the storage containing the reference to the window) with the key.
After this, whenever this thread calls pthread_getspecific(), passing the global key, it gets the value that was associated with this key by this thread when it called pthread_setspecific().
When a thread terminates, calls are made to the destructor functions that were set up in pthread_key_create(). Each destructor function is called only if the terminating thread established a value for the key by calling pthread_setspecific().
Get the Thread Identifier
pthread_self(3THR)
Use pthread_self(3THR) to get the thread identifier of the calling thread.
Prototype:
pthread_t	 pthread_self(void);
pthread_t tid;
tid = pthread_self();
Return Values
pthread_self() returns the thread identifier of the calling thread.
Compare Thread IDs
pthread_equal(3THR)
Use pthread_equal(3THR) to compare the thread identification numbers of two threads.
Prototype:
int	 pthread_equal(pthread_t tid1, pthread_t tid2);
pthread_t tid1, tid2;
int ret;
ret = pthread_equal(tid1, tid2);
Return Values
pthread_equal() returns a nonzero value when tid1 and tid2 are equal; otherwise, zero is returned. When either tid1 or tid2 is an invalid thread identification number, the result is unpredictable.
Initializing Threads
pthread_once(3THR)
Use pthread_once(3THR) to call an initialization routine the first time pthread_once(3THR) is called. Subsequent calls to pthread_once() have no effect.
Prototype:
int	 pthread_once(pthread_once_t *once_control,
    void (*init_routine)(void));
pthread_once_t once_control = PTHREAD_ONCE_INIT;
int ret;
ret = pthread_once(&once_control, init_routine);
The once_control parameter determines whether the associated initialization routine has been called.
Return Values
pthread_once() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, pthread_once() fails and returns the corresponding value.
EINVAL
once_control or init_routine is NULL.
Yield Thread Execution
sched_yield(3RT)
Use sched_yield(3RT) to cause the current thread to yield its execution in favor of another thread with the same or greater priority.
Prototype:
int	 sched_yield(void);
#include <sched.h>
int ret;
ret = sched_yield();
Return Values
sched_yield() returns zero after completing successfully. Otherwise -1 is returned and errno is set to indicate the error condition.
ENOSYS
sched_yield(3RT) is not supported in this implementation.
Set the Thread Priority
pthread_setschedparam(3THR)
Use pthread_setschedparam(3THR) to modify the priority of an existing thread. This function has no effect on scheduling policy.
Prototype:
int	 pthread_setschedparam(pthread_t tid, int policy,
    const struct sched_param *param);
pthread_t tid;
int ret;
struct sched_param param;
int priority;
/* sched_priority will be the priority of the thread */
sched_param.sched_priority = priority;
/* only supported policy, others will result in ENOTSUP */
policy = SCHED_OTHER;
/* scheduling parameters of target thread */
ret = pthread_setschedparam(tid, policy, &param);
Return Values
pthread_setschedparam() returns zero after completing successfully. Any other return value indicates that an error occurred. When either of the following conditions occurs, the pthread_setschedparam() function fails and returns the corresponding value.
EINVAL
The value of the attribute being set is not valid.
ENOTSUP
An attempt was made to set the attribute to an unsupported value.
Get the Thread Priority
pthread_getschedparam(3THR)
pthread_getschedparam(3THR) gets the priority of the existing thread.
Prototype:
int	 pthread_getschedparam(pthread_t tid, int policy,
    struct schedparam *param);
pthread_t tid;
sched_param param;
int priority;
int policy;
int ret;
ret = pthread_getschedparam (tid, &policy, &param);
/* sched_priority contains the priority of the thread */
priority = param.sched_priority;
Return Values
pthread_getschedparam() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, the function fails and returns the corresponding value.
ESRCH
The value specified by tid does not refer to an existing thread.
Send a Signal to a Thread
pthread_kill(3THR)
Use pthread_kill(3THR) to send a signal to a thread.
Prototype:
int	 pthread_kill(thread_t tid, int sig);
#include <signal.h>
int sig;
pthread_t tid;
int ret;
ret = pthread_kill(tid, sig);
pthread_kill() sends the signal sig to the thread specified by tid. tid must be a thread within the same process as the calling thread. The sig argument must be from the list given in signal(5).
When sig is zero, error checking is performed but no signal is actually sent. This can be used to check the validity of tid.
Return Values
pthread_kill() returns zero after completing successfully. Any other return value indicates that an error occurred. When either of the following conditions occurs, pthread_kill() fails and returns the corresponding value.
EINVAL
sig is not a valid signal number.
ESRCH
tid cannot be found in the current process.
Access the Signal Mask of the Calling Thread
pthread_sigmask(3THR)
Use pthread_sigmask(3THR) to change or examine the signal mask of the calling thread.
Prototype:
int	pthread_sigmask(int how, const sigset_t *new, sigset_t *old);
#include <signal.h>
int ret;
sigset_t old, new;
ret = pthread_sigmask(SIG_SETMASK, &new, &old); /* set new mask */
ret = pthread_sigmask(SIG_BLOCK, &new, &old); /* blocking mask */
ret = pthread_sigmask(SIG_UNBLOCK, &new, &old); /* unblocking */
how determines how the signal set is changed. It can have one of the following values:
When the value of new is NULL, the value of how is not significant and the signal mask of the thread is unchanged. So, to inquire about currently blocked signals, assign a NULL value to the new argument.
The old variable points to the space where the previous signal mask is stored, unless it is NULL.
Return Values
pthread_sigmask() returns zero when it completes successfully. Any other return value indicates that an error occurred. When the following condition occurs, pthread_sigmask() fails and returns the corresponding value.
EINVAL
The value of how is not defined.
Forking Safely
pthread_atfork(3THR)
See the discussion about pthread_atfork(3THR) in The Solution—pthread_atfork(3THR).
Prototype:
int pthread_atfork(void (*prepare) (void), void (*parent) (void),
    void (*child) (void) );
Terminate a Thread
pthread_exit(3THR)
Use pthread_exit(3THR) to terminate a thread.
Prototype:
void	 pthread_exit(void *status);
void *status;
pthread_exit(status); /* exit with status */
The pthread_exit() function terminates the calling thread. All thread-specific data bindings are released. If the calling thread is not detached, then the thread's ID and the exit status specified by status are retained until the thread is waited for via pthread_join(). Otherwise, status is ignored and the thread's ID can be reclaimed immediately. For information on thread detachment, see Set Detach State.
Return Values
The calling thread terminates with its exit status set to the contents of status.
Finishing Up
A thread can terminate its execution in the following ways:
The default behavior of a thread is to linger until some other thread has acknowledged its demise by “joining” with it. This is the same as the default pthread_create() attribute being nondetached; see pthread_detach(3THR). The result of the join is that the joining thread picks up the exit status of the dying thread and the dying thread vanishes.
An important special case arises when the initial thread — the one calling main(),— returns from calling main() or calls exit(3C). This action causes the entire process to be terminated, along with all its threads. So take care to ensure that the initial thread does not return from main() prematurely.
Note that when the main thread merely calls pthread_exit(3THR), it terminates only itself—the other threads in the process, as well as the process, continue to exist. (The process terminates when all threads terminate.)
Cancellation
Cancellation allows a thread to terminate the execution of any other thread, or all threads, in the process. Cancellation is an option when all further operations of a related set of threads are undesirable or unnecessary.
One example of thread cancellation is an asynchronously generated cancel condition, such as, when a user requesting to close or exit some running application. Another example is the completion of a task undertaken by a number of threads. One of the threads might ultimately complete the task while the others continue to operate. Since they are serving no purpose at that point, they all should be cancelled.
There are dangers in performing cancellations. Most deal with properly restoring invariants and freeing shared resources. A thread that is cancelled without care might leave a mutex in a locked state, leading to a deadlock. Or it might leave a region of memory allocated with no way to identify it and therefore no way to free it.
The pthreads library specifies a cancellation interface that permits or forbids cancellation programmatically. The library defines the set of points at which cancellation can occur (cancellation points). It also allows the scope of cancellation handlers, which provide clean up services, to be defined so that they are sure to operate when and where intended.
Placement of cancellation points and the effects of cancellation handlers must be based on an understanding of the application. A mutex is explicitly not a cancellation point and should be held only the minimal essential time.
Limit regions of asynchronous cancellation to sequences with no external dependencies that could result in dangling resources or unresolved state conditions. Take care to restore cancellation state when returning from some alternate, nested cancellation state. The interface provides features to facilitate restoration: pthread_setcancelstate(3THR) preserves the current cancel state in a referenced variable; pthread_setcanceltype(3THR) preserves the current cancel type in the same way.
Cancellations can occur under three different circumstances:
By default, cancellation can occur only at well-defined points as defined by the POSIX standard.
In all cases, take care that resources and state are restored to a condition consistent with the point of origin.
Cancellation Points
Be careful to cancel a thread only when cancellation is safe. The pthreads standard specifies several cancellation points, including:
Cancellation is enabled by default. At times you might want an application to disable cancellation. This has the result of deferring all cancellation requests until they are enabled again.
See pthread_setcancelstate(3THR)for information about disabling cancellation.
Cancel a Thread
pthread_cancel(3THR)
Use pthread_cancel(3THR) to cancel a thread.
Prototype:
int	pthread_cancel(pthread_t thread);
pthread_t thread;
int ret;
ret = pthread_cancel(thread);
How the cancellation request is treated depends on the state of the target thread. Two functions, pthread_setcancelstate(3THR) and pthread_setcanceltype(3THR), determine that state.
Return Values
pthread_cancel() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, the function fails and returns the corresponding value.
ESRCH
No thread could be found corresponding to that specified by the given thread ID.
Enable or Disable Cancellation
Use pthread_setcancelstate(3THR) to enable or disable thread cancellation. When a thread is created, thread cancellation is enabled by default.
Prototype:
int	pthread_setcancelstate(int state, int *oldstate);
int oldstate;
int ret;
/* enabled */
ret = pthread_setcancelstate(PTHREAD_CANCEL_ENABLE, &oldstate);
/* disabled */
ret = pthread_setcancelstate(PTHREAD_CANCEL_DISABLE, &oldstate);
Return Values
pthread_setcancelstate() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, the pthread_setcancelstate() function fails and returns the corresponding value.
EINVAL
The state is not PTHREAD_CANCEL_ENABLE or PTHREAD_CANCEL_DISABLE.
Set Cancellation Type
Use pthread_setcanceltype(3THR) to set the cancellation type to either deferred or asynchronous mode. When a thread is created, the cancellation type is set to deferred mode by default. In deferred mode, the thread can be cancelled only at cancellation points. In asynchronous mode, a thread can be cancelled at any point during its execution. Using asynchronous mode is discouraged.
Prototype:
int	pthread_setcanceltype(int type, int *oldtype);
int oldtype;
int ret;
/* deferred mode */
ret = pthread_setcanceltype(PTHREAD_CANCEL_DEFERRED, &oldtype);
/* async mode*/
ret = pthread_setcanceltype(PTHREAD_CANCEL_ASYNCHRONOUS, &oldtype);
Return Values
pthread_setcanceltype() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, the function fails and returns the corresponding value.
EINVAL
The type is not PTHREAD_CANCEL_DEFERRED or PTHREAD_CANCEL_ASYNCHRONOUS.
Create a Cancellation Point
pthread_testcancel(3THR)
Use pthread_testcancel(3THR) to establish a cancellation point for a thread.
Prototype:
void pthread_testcancel(void);
pthread_testcancel();
The pthread_testcancel() function is effective when thread cancellation is enabled and in deferred mode. Calling this function while cancellation is disabled has no effect.
Be careful to insert pthread_testcancel() only in sequences where it is safe to cancel a thread. In addition to programmatically establishing cancellation points through the pthread_testcancel() call, the pthreads standard specifies several cancellation points. See Cancellation Pointsfor more details.
There is no return value.
Push a Handler Onto the Stack
Use cleanup handlers to restore conditions to a state consistent with that at the point of origin, such as cleaning up allocated resources and restoring invariants. Use the pthread_cleanup_push(3THR) and pthread_cleanup_pop(3THR) functions to manage the handlers.
Cleanup handlers are pushed and popped in the same lexical scope of a program. They should always match; otherwise compiler errors will be generated.
Use pthread_cleanup_push(3THR) to push a cleanup handler onto a cleanup stack (LIFO).
Prototype:
void pthread_cleanup_push(void(*routine)(void *), void *args);
/* push the handler "routine" on cleanup stack */
pthread_cleanup_push (routine, arg);
Pull a Handler Off the Stack
Use pthread_cleanup_pop(3THR) to pull the cleanup handler off the cleanup stack.
A nonzero argument in the pop function removes the handler from the stack and executes it. An argument of zero pops the handler without executing it.
pthread_cleanup_pop() is effectively called with a nonzero argument if a thread either explicitly or implicitly calls pthread_exit(3THR) or if the thread accepts a cancel request.
Prototype:
void pthread_cleanup_pop(int execute);
/* pop the "func" out of cleanup stack and execute "func" */
pthread_cleanup_pop (1);
/* pop the "func" and DONT execute "func" */
pthread_cleanup_pop (0);
There are no return values.
