The class field names the class to which an object belongs. Using classes is an optional package design feature, and is discussed in detail in Writing Class Action Scripts.
If you do not use classes, an object belongs to the none
class, and when you execute the pkgmk command to build your
package, it will insert the CLASSES=none
parameter in the pkginfo file for you. Files with file
type i should leave the class
field blank.
