Given the prototype file created by the pkgproto command in Creating a prototype File With the pkgproto Command, there are several modifications that need to be made.
There needs to be an entry for the pkginfo file.
The path fields need to be modified to be the path1=path2 format, since the package source is in /home/jane. (Since the package source is a hierarchical directory, and the !search command does not search recursively, it may be easier to use the path1=path2 format.)
The owner and group fields should contain the names of existing users and groups on the target system. That is, the owner jane will result in an error since this owner is not part of the SunOSTM operating system.
The modified prototype file looks like:
i pkginfo=/home/jane/InfoFiles/pkginfo d none SUNWcadap=/home/jane/SUNWcadap 0755 root sys d none SUNWcadap/demo=/home/jane/SUNWcadap/demo 0755 root bin f none SUNWcadap/demo/file1=/home/jane/SUNWcadap/demo/file1 0555 root bin d none SUNWcadap/srcfiles=/home/jane/SUNWcadap/srcfiles 0755 root bin f none SUNWcadap/srcfiles/file5=/home/jane/SUNWcadap/srcfiles/file5 0555 root bin f none SUNWcadap/srcfiles/file6=/home/jane/SUNWcadap/srcfiles/file6 0555 root bin d none SUNWcadap/lib=/home/jane/SUNWcadap/lib 0755 root bin f none SUNWcadap/lib/file2=/home/jane/SUNWcadap/lib/file2 0644 root bin d none SUNWcadap/man=/home/jane/SUNWcadap/man 0755 bin bin f none SUNWcadap/man/windex=/home/jane/SUNWcadap/man/windex 0644 root other d none SUNWcadap/man/man1=/home/jane/SUNWcadap/man/man1 0755 bin bin f none SUNWcadap/man/man1/file4.1=/home/jane/SUNWcadap/man/man1/file4.1 0444 bin bin f none SUNWcadap/man/man1/file3.1=/home/jane/SUNWcadap/man/man1/file3.1 0444 bin bin |
