You can get a pkginfo display in any of three formats: short, extracted, and long.
The short format is the default. It shows only the category, package abbreviation, and full package name, as shown in The Default pkginfo Display.
The extracted format shows the package abbreviation, package name, package architecture (if available), and package version (if available). Use the -x option to request the extracted format as shown in the next example.
$ pkginfo -x
SUNWipc Interprocess Communications
(sparc) 11.8.0,REV=1999.08.20.12.37
SUNWisolc XSH4 conversion for ISO Latin character sets
(sparc) 1.0,REV=1999.07.10.10.10
SUNWkcspf KCMS Optional Profiles
(sparc) 1.1.2,REV=1.5
SUNWkcspg KCMS Programmers Environment
Using the -l option produces a display in the long format showing all of the available information about a package, as in the following example.
$ pkginfo -l SUNWcadap
PKGINST: SUNWcadap
NAME: Chip designers need CAD application software to
design abc chips. Runs only on xyz hardware and is installed
in the usr partition.
CATEGORY: system
ARCH: SPARC
VERSION: release 1.0
BASEDIR: /opt
PSTAMP: system980706083849
INSTDATE: Jul 7 1999 09:58
STATUS: completely installed
FILES: 13 installed pathnames
6 directories
3 executables
3121 blocks used (approx)
