PKG=SUNWsst NAME=Simple SCSI Target Driver VERSION=1 CATEGORY=system ARCH=sparc VENDOR=Sun Microsystems BASEDIR=/opt CLASSES=sed |
For example, this case study uses the hierarchical layout of the package objects shown in the figure below.
The package objects are installed in the same places as they are in
the pkg directory above. The driver modules (sst and sst.conf) are installed into /usr/kernel/drv and the include file is installed into /usr/include/sys/scsi/targets. The sst, sst.conf, and sst_def.h files are absolute objects.
The test program, sstest.c, and its directory SUNWsst are relocatable; their installation location is set by the BASEDIR parameter.
The remaining components of the package (all the control files) go in the top directory of the package on the development machine, except the sed class script. This is called devlink.tab after the file it modifies, and goes into etc, the directory containing the real devlink.tab file.
From the pkg directory, run the pkgproto command as follows:
find usr SUNWsst -print | pkgproto > prototype |
The output from the above command looks like this:
d none usr 0775 pms mts d none usr/include 0775 pms mts d none usr/include/sys 0775 pms mts d none usr/include/sys/scsi 0775 pms mts d none usr/include/sys/scsi/targets 0775 pms mts f none usr/include/sys/scsi/targets/sst_def.h 0444 pms mts d none usr/kernel 0775 pms mts d none usr/kernel/drv 0775 pms mts f none usr/kernel/drv/sst 0664 pms mts f none usr/kernel/drv/sst.conf 0444 pms mts d none SUNWsst 0775 pms mts f none SUNWsst/sstest.c 0664 pms mts |
This prototype file is not yet complete. To complete this file, you need to make the following modifications:
Insert the entries for the control files (file type i), because they have a different format than the other package objects.
Remove entries for directories that already exist on the target system.
Change the access permission and ownership for each entry.
Prepend a slash to the absolute package objects.
This is the final prototype file:
i pkginfo i postinstall i preremove i copyright e sed /etc/devlink.tab ? ? ? f none /usr/include/sys/scsi/targets/sst_def.h 0644 bin bin f none /usr/kernel/drv/sst 0755 root sys f none /usr/kernel/drv/sst.conf 0644 root sys d none SUNWsst 0775 root sys f none SUNWsst/sstest.c 0664 root sys |
The questions marks in the entry for the sed script indicate that the access permissions and ownership of the existing file on the installation machine should not be changed.
In the driver example, a sed class script is used to add an entry for the driver to the file /etc/devlink.tab. This file is used by the devlinks command to create symbolic links from /dev into /devices. This is the sed script:
# sed class script to modify /etc/devlink.tab !install /name=sst;/d $i\ type=ddi_pseudo;name=sst;minor=character rsst\\A1 !remove /name=sst;/d |
The pkgrm command does not run the removal part of the script. You may need to add a line to the preremove script to run sed directly to remove the entry from the /etc/devlink.tab file.
In this example, all the script needs to do is run the add_drv command.
# Postinstallation script for SUNWsst # This does not apply to a client. if [$PKG_INSTALL_ROOT = "/" -o -z $PKG_INSTALL_ROOT]; then SAVEBASE=$BASEDIR BASEDIR=””; export BASEDIR /usr/sbin/add_drv sst STATUS=$? BASEDIR=$SAVEBASE; export BASEDIR if [ $STATUS -eq 0 ] then exit 20 else exit 2 fi else echo "This cannot be installed onto a client." exit 2 fi |
The add_drv command uses the BASEDIR parameter, so the script has to unset BASEDIR before running the command, and restore it afterwards.
One of the actions of the add_drv command is to run devlinks, which uses the entry placed in /etc/devlink.tab by the sed class script to create the /dev entries for the driver.
The exit code from the postinstall script is significant. The exit code 20 tells the pkgadd command to tell the user to reboot the system (necessary after installing a driver), and the exit code 2 tells the pkgadd command to tell the user that the installation partially failed.
In the case of this driver example, it removes the links in /dev and runs the rem_drv command on the driver.
# Pre removal script for the sst driver echo “Removing /dev entries” /usr/bin/rm -f /dev/rsst* echo “Deinstalling driver from the kernel” SAVEBASE=$BASEDIR BASEDIR=””; export BASEDIR /usr/sbin/rem_drv sst BASEDIR=$SAVEBASE; export BASEDIR exit |
The script removes the /dev entries itself; the /devices entries are removed by the rem_drv command.
This is a simple ASCII file containing the text of a copyright notice. The notice is displayed at the beginning of package installation exactly as it appears in the file.
Copyright (c) 1999 Drivers-R-Us, Inc. 10 Device Drive, Thebus, IO 80586 All rights reserved. This product and related documentation is protected by copyright and distributed under licenses restricting its use, copying, distribution and decompilation. No part of this product or related documentation may be reproduced in any form by any means without prior written authorization of Drivers-R-Us and its licensors, if any. |
