trap 'exit 3' 15 # determine if and where general executables should be placed ans=`ckyorn -d y \ -p "Should executables included in this package be installed" ` || exit $? if [ "$ans" = y ] then CLASSES="$CLASSES bin" NCMPBIN=`ckpath -d /usr/ncmp/bin -aoy \ -p "Where should executables be installed" ` || exit $? fi # determine if emacs editor should be installed, and if it should # where should the associated macros be placed ans=`ckyorn -d y \ -p "Should emacs editor included in this package be installed" ` || exit $? if [ "$ans" = y ] then CLASSES="$CLASSES emacs" EMACS=`ckpath -d /usr/ncmp/lib/emacs -aoy \ -p "Where should emacs macros be installed" ` || exit $? fi |
Note that a request script can exit without leaving any files on the file system. For installations on Solaris versions prior to 2.5 and compatible versions (where no checkinstall script may be used) the request script is the correct place to test the file system in any manner necessary to ensure that the installation will succeed. When the request script exits with code 1, the installation will quit cleanly.
These example files show the use of parametric paths to establish multiple
base directories. However, the preferred method involves use of the BASEDIR parameter which is managed and validated
by the pkgadd command. Whenever multiple base directories
are used, take special care to provide for installation of multiple versions
and architectures on the same platform.
