This example shows what a traditional relocatable package may look like. The package is to be located in /opt/SUNWstuf, and its pkginfo file and pkgmap file might look like this.
# pkginfo file PKG=SUNWstuf NAME=software stuff ARCH=sparc VERSION=1.0.0,REV=1.0.5 CATEGORY=application DESC=a set of utilities that do stuff BASEDIR=/opt VENDOR=Sun Microsystems, Inc. HOTLINE=Please contact your local service provider EMAIL= MAXINST=1000 CLASSES=none PSTAMP=hubert990707141632 |
: 1 1758 1 d none SUNWstuf 0775 root bin 1 d none SUNWstuf/EZstuf 0775 root bin 1 f none SUNWstuf/EZstuf/dirdel 0555 bin bin 40 773 751310229 1 f none SUNWstuf/EZstuf/usrdel 0555 bin bin 40 773 751310229 1 f none SUNWstuf/EZstuf/filedel 0555 bin bin 40 773 751310229 1 d none SUNWstuf/HRDstuf 0775 root bin 1 f none SUNWstuf/HRDstuf/mksmart 0555 bin bin 40 773 751310229 1 f none SUNWstuf/HRDstuf/mktall 0555 bin bin 40 773 751310229 1 f none SUNWstuf/HRDstuf/mkcute 0555 bin bin 40 773 751310229 1 f none SUNWstuf/HRDstuf/mkeasy 0555 bin bin 40 773 751310229 1 i pkginfo 348 28411 760740163 1 i postinstall 323 26475 751309908 1 i postremove 402 33179 751309945 1 i preinstall 321 26254 751310019 1 i preremove 320 26114 751309865 |
This is referred to as the traditional method because every package
object is installed to the base directory defined by the BASEDIR parameter from the pkginfo file.
For example, the first object in the pkgmap file is installed
as the directory /opt/SUNWstuf.
