# request script
for SUNWstuf to walk a parametric path
PATH=/usr/sadm/bin:${PATH} # use admin utilities
MSG="The target directory $LOCAL_BASE already contains \
different architecture or version of $PKG. This package \
could be installed at the unused target directory $WRKNG_BASE."
PROMPT="Do you want to use to the proposed directory? "
HELP="A response of \"y\" will install to the proposed directory \
and continue, \"n\" will request a different directory. If \
the option \"-a none\" was used, press the <RETURN> key and \
enter an unused base directory when it is requested."
DIRPROMPT="Select a relative target directory under $BASEDIR/"
DIRHELP="The package $PKG will be installed at the location entered."
SUSPEND="Suspending installation at user request using error \
code 1."
NUBD_MSG="The location of this package is not the default. Be \
sure to update any applicable search paths with the actual \
location of the binaries which are at $WRKNG_BASE/EZstuf \
and $WRKNG_BASE/HRDstuf."
Changed=""
Suffix="0"
# Determine if this product is actually installed in the working
# base directory.
Product_is_present () {
if [ -d $WRKNG_BASE/EZstuf -o -d $WRKNG_BASE/HRDstuf ]; then
return 1
else
return 0
fi
if [ ${BASEDIR} ]; then
# This may be an old version of Solaris. In the latest Solaris
# CLIENT_BASEDIR won't be defined yet. In older versions it is.
if [ ${CLIENT_BASEDIR} ]; then
LOCAL_BASE=$BASEDIR/$SUBBASE
else # The base directory hasn't been processed yet
LOCAL_BASE=${PKG_INSTALL_ROOT}$BASEDIR/$SUBBASE
fi
WRKNG_BASE=$LOCAL_BASE
# See if the base directory is already in place and walk it if
# possible
while [ -d ${WRKNG_BASE} -a Product_is_present ]; do
# There is a conflict
# Is this an update of the same arch & version?
if [ ${UPDATE} ]; then
exit 0 # It's out of our hands.
else
# So this is a different architecture or
# version than what is already there.
# Walk the base directory
Suffix=`expr $Suffix + 1`
WRKNG_BASE=$LOCAL_BASE.$Suffix
Changed="true"
fi
done
# So now we can propose a base directory that isn't claimed by
# any of our other versions.
if [ $Changed ]; then
puttext "$MSG"
result=`ckyorn -Q -d "a" -h "$HELP" -p "$PROMPT"`
if [ $? -eq 3 ]; then
puttext "$SUSPEND"
exit 1
fi
if [ $result="n" ]; then
WRKNG_BASE=`ckpath -lyw -d "$WRKNG_BASE" -h "$DIRHELP" \
-p "$DIRPROMPT"`
elif [ $result="a" ]; then
exit 0
else
exit 1
fi
echo SUBBASE=$SUBBASE.$Suffix >> $1
puttext "$NUBD_MSG"
fi
fi
exit 0
