The following sections changed.
Maximum size of system V shared memory segment that can be created. This parameter is an upper limit that is checked before the system sees if it actually has the physical resources to create the requested memory segment.
to:
Attempts to create a shared memory section whose size is zero or whose size is larger than the specified value will fail with an EINVAL error.
1,048,576
to:
8,388,608
