Become superuser on the system where you are attaching the card reader.
Add the Sun SCRI Internal Card Reader 1 by typing, for example, the following command on one line:
# smartcard -c admin -t terminal -j com.sun.opencard.terminal.scm.SCMI2c.SCMI2cCardTerminalFactory -x add -d /dev/scmi2c1 -r MyInternalReader -n SunISCRI |
Stop ocfserv.
# pkill ocfserv |
The ocfserv process is restarted the next time you use the Smartcard Console or execute the smartcard command.
