Supported Card Readers
Solaris Smartcard supports two external card readers, the iButton and
the Sun SCRI External Reader 1, and an internal card reader, the Sun SCRI
Internal Card Reader 1.
The following table shows the supported card readers and the corresponding
values you need to supply to add them.
Table 3–1 Card Readers Supported
Reader Type
Card Terminal Factory Name
Reader Model Name
Sun SCRI External Card Reader
1
com.sun.opencard.terminal.scm.SCMStc.SCMStcCardTerminalFactory
SunSCRI
iButton
com.ibutton.oc.terminal.jib.iButtonCardTerminalFactory
DS1402
Sun SCRI Internal Card Reader 1
com.sun.opencard.terminal.scm.SCMI2c.SCMI2cCardTerminalFactory
SunISCRI
Adding a Card Reader (Command Line)
You add a card reader by using the smartcard -c admin
command with the following syntax:
smartcard -c admin -t terminal -j card_terminal_factory_name -x add -d device_pathname -r user_friendly_reader_name -n card_reader_model
-c admin
Indicates that you are viewing or modifying
OCF properties.
-t terminal
Indicates that you are about to configure
a card reader.
Defines the card terminal factory name of the card reader
type. See the specific Card Terminal Factory Name in the procedures below.
-x add
Indicates that you want to add a card reader.
-d device_pathname
Specifies the
device port where you have plugged in the card reader.
Specifies a unique
name for the reader.
-n reader_model_name
Designates the
model name of the card reader. See the specific card reader model name in
Refer to the smartcard(1M) man page for more information.
To Add an iButton Reader
Attach the external card reader to the system.
Physically attach the external smart card reader to the serial port,
following instructions in the card reader documentation.
Become superuser on the system where you are attaching the card reader.
Add the iButton reader by typing, for example, the following on one
line:
# smartcard -c admin -t terminal
-j com.ibutton.oc.terminal.jib.iButtonCardTerminalFactory
-x add -d /dev/cua/b -r MyButtonReader -n DS1402
-c admin
OCF properties.
-t terminal
Indicates you are configuring a card
reader.
Identifies
the card terminal factory name of the iButton reader.
Be careful
to type the card terminal factory name following -j option
exactly as shown in the procedure above, with no spaces or returns between
characters.
-x add
reader.
-d /dev/scmi2c0
Defines the device port where the card reader
is attached.
-r MyButtonReader
Specifies a unique
name for the iButton reader.
-n DS1402
Indicates the model name for the iButton card
reader.
Stop ocfserv.
The ocfserv process is restarted the next time you
use the Smartcard Console or the smartcard command.
To Add a Sun SCRI External Card Reader 1
Add the Sun SCRI External Card Reader 1 by typing, for example, the
following command on one line:
-j com.sun.opencard.terminal.scm.SCMStc.SCMStcCardTerminalFactory
-x add -d /dev/cua/b -r MyExternalReader -n SunSCRI
-c admin
OCF properties.
-t terminal
reader.
-j
The card terminal factory name of the
Sun SCRI External Card Reader 1.
Be careful to type the card terminal
factory name following -j option exactly as shown in the procedure
above, with no spaces or returns between characters.
-x add
-d /dev/scmi2c0
is attached.
-r MyExternalReader
Specifies a unique
name for the SCRI External Card Reader 1.
-n SunSCRI
Indicates the model name for the SCRI External
Card Reader 1.
Stop ocfserv.
use the Smartcard Console or execute the smartcard command.
To Add a Sun SCRI Internal Card Reader 1
Add the Sun SCRI Internal Card Reader 1 by typing, for example, the
-j com.sun.opencard.terminal.scm.SCMI2c.SCMI2cCardTerminalFactory
-x add -d /dev/scmi2c1 -r MyInternalReader -n SunISCRI
-c admin
OCF properties.
-t terminal
reader.
The card terminal factory name of the Sun SCRI Internal Card Reader 1.
Be careful to type the card terminal factory name following -j
option exactly as shown in the procedure above, with no spaces or returns
between characters.
-x add
reader.
-d /dev/scmi2c0
is attached. For example, /dev/scmi2cn,
where n in scmi2cn is the nthe SunISCRI reader on
the system.
-r MyInternalReader
Specifies a unique
name for the SCRI Internal Card Reader 1.
-n SunISCRI
Indicates the model name for the SCRI Internal
Card Reader 1.
Stop ocfserv.
