The following table lists the Solaris Smartcard packages added during a Solaris 9 installation.
Table 1–1 Solaris Smartcard Packages|
Package Name |
Description |
SUNWjcom |
Java Communications API for smart card support - Java code and Native code |
SUNWjcomx |
Java Communications API for smart card support - Native code (64–bit) |
SUNWjib |
Dallas Semiconductor serial iButton OCF Card Terminal Driver |
SUNWocf |
Open Card Framework - core libraries and utilities |
SUNWocfr |
Open Card Framework - configuration files |
SUNWocfh |
Open Card Framework - header files |
SUNWocfx |
Open Card Framework - core libraries (64–bit) |
SUNWpamsc |
Pluggable Authentication Module for smart card authentication |
SUNWpamsx |
Pluggable Authentication Module for smart card authentication (64–bit) |
SUNWscgui |
Solaris Smartcard Console |
SUNWscmos |
Smart OS used by SCM card terminal driver |
SUNWscmsc |
Sun SCRI OCF Card Terminal Driver |
To remove a package, use the standard pkgrm command. Reinstall the package using the pkgadd command.
See “Managing Software (Tasks)” in System Administration Guide: Basic Administration for information on using these commands.
