Solaris Smartcard Administration Guide
To Enable Debugging (Command Line)
Use the following procedure to enable smart card debugging.
  1. Become superuser.
  2. Enable smart card debugging by setting debugging=1.
    # smartcard -c admin -x modify debugging=1
    In the following example, the location of the ocfserv debugging file is changed by specifying the -x modify debugging.filename option and a fully qualified file name for the debugging file.
    # smartcard -c admin -x modify debugging.filename=/var/tmp/sc.debug
