This command is appropriate for all smart cards devices supported by Solaris Smartcard. Insert the card in the card reader. For Smartcard Console instructions, see To Set Up a User Profile and To Change the PIN on a Card.
Set the login name, password, and application for the card by typing the following on one line:
# smartcard -c init -A A000000062030400 -P '$$$$java' user=anyone password=changeme application=dtlogin |
In the example, the username is set to anyone, the password to changeme, and the application is dtlogin. The username and password can be set to any value; these will be changed by a system administrator or the user when the card is issued. See To Set Up a User Profile for instructions.
You must enter the loaded applet ID and the current PIN. The -A A000000062030400 part of the command specifies the SolarisAuthApplet applet ID. You must enclose the default PIN, $$$$java, or any PIN containing shell special-characters (such as $) within single quotes. Otherwise, the shell tries to interpret the PIN as a variable, and the command fails.
