The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions|
 Typeface or Symbol  |
 Meaning  |
 Example  |
 AaBbCc123  | The names of commands, files, and directories; on-screen computer output |
 Edit your .login file. Use ls -a to list all files. machine_name% you have mail.  |
 AaBbCc123  | What you type, contrasted with on-screen computer output |
 machine_name% su Password:  |
 AaBbCc123  | Command-line placeholder: replace with a real name or value |
 To delete a file, type rm filename.  |
 AaBbCc123  |
 Book titles, new words, or terms, or words to be emphasized.  |
 Read Chapter 6 in User's Guide. These are called class options. You must be root to do this.  |
