Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Appendix A dtconfig(1) Man Page
NAME
     dtconfig - desktop configuration utility
SYNOPSIS
     dtconfig [-d |-e |-kill |-reset |-p |-inetd |-inetd.ow ]
DESCRIPTION
     Desktop configuration utility.  Integrates CDE with the
     operating system of the underlying platform.  System root
     login privilege is required to use dtconfig.
OPTIONS
     -d   Disables desktop auto-start feature.  At end of boot
          cycle, platform's native text based login mechanism
          will be used.
     -e   Enable's desktop auto-start feature.  Desktop login
     -kill
          Kill desktop (window based) login process and any user
          sessions associated with it.  Return control to
          system's native text based console.
     -reset
          Tell desktop (window based) login process to reread its
          configuration file to incorporate any changes.
     -p   Printer actions for any printer known to platform will
          be created if such print actions do not already exist
          in the platform's actions database.  This option is
          executed automatically at boot time if desktop auto-
          start has been enabled.
     -inetd
          Adds /usr/dt/bin daemons to the /etc/inetd.conf file.
          Specific CDE background daemon setup includes
          rpc.ttdbserverd (ToolTalk), rpc.cmsd (Calendar
          Manager), and dtspcd (subprocess control).  This -inetd
          option is called automatically by Solaris CDE package
          installs.  This -inetd option is also useful for CDE
          daemon setup outside of normal Solaris CDE install,
          including system setup where /usr/dt has simply been
          mounted from some remote fileserver exporting the
          /usr/dt directory.
     -inetd.ow
          Switches the ToolTalk and Calendar Manager daemons
          (rpc.ttdbserverd & rpc.cmsd) start lines in
          /etc/inetd.conf back to the older /usr/openwin/bin
          area.  This option is called automatically by Solaris
          CDE package remove scripts when needed.  It is also
          useful outside of normal Solaris package remove opera-
          tions when /usr/dt is about to be manually removed or
          unmounted.
RETURN VALUES
     0    Successful completion
    >0    Error condition
FILES
     /usr/dt/bin/dtconfig       location of dtconfig utility
SEE ALSO
     dtlogin (1), dtprintinfo (1)
