Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Configuring Base Operating System Networking for the Desktop
The desktop requires the following base networking configuration:
Providing Login Accounts to Users
This section describes the login account requirements for desktop networking.
Users must have a login account on:
Providing Consistent User and Group IDs
UNIX users are identified by a login name and a numeric user ID (UID). In a desktop network, the user should have the same login name and UID on all client and server systems.
UNIX users are also assigned to one or more login groups. Each group has a group name and a numeric group ID (GID). In a desktop network, all systems should use consistent group names and group IDs.
For more information, see the id(1) or id(1M) man page.
Configuring Distributed File System Access
The desktop uses NFS for sharing files between systems. You must identify all the file systems in your network that contain shared files and ensure that they are correctly mounted on all appropriate systems.
Typically, you must provide the following remote file access:
Providing a Networked Home Directory
A desktop network works most effectively when users have a single home directory that is shared among all client and server systems on the network.
A networked home directory enables users to use different systems in the network without losing personal customizations and configurations. This is because personal customizations and the information required to restore the previous session are saved in subdirectories of the home directory.
A common home directory is also required by:
File-Name Consistency
You should configure the network so that users can access their data files from all systems using the same name. This is known as providing file-name consistency, and is usually accomplished by creating appropriate symbolic links. For example you can configure every system so that each user's home directory is available as /users/login_name by creating a symbolic link to the actual mount location of the directory.
Configuring Access to Remote Printers
The desktop uses the lp print spooler for accessing local or remote printers. See the lpadmin(1M) man page for information on configuring the lp spooler.
Before attempting to print using the desktop graphical interface, you should test that you can correctly print to all printers using the lp command.
Be sure to use consistent printer device names. For example, if a particular printer is known as Postscript1 on the system to which it is directly connected, all other systems accessing the printer remotely should also use the name Postscript1.
Configuring Electronic Mail
The desktop mailer uses sendmail for delivering mail between systems. See the sendmail(1M) man page for more information on how to configure email connectivity.
Before attempting to send or receive mail from the desktop, you should test that you can correctly send and receive mail using the mailx command.
Configuring X Authorization
The desktop uses the default X mechanism for authorizing remote applications (X clients) to access a local display. The easiest way to configure this is to provide a networked home directory for each user. This ensures that the following requirements are met:
