The syntax for the variables DTSPSYSAPPHOSTS and DTSPUSERAPPHOSTS is:
VARIABLE=location [,location...]
where location can have the syntax:
/path—specifies a directory on the local (session server) system. Use this syntax to add a local directory.
hostname:—specifies the system-wide directory /etc/dt/appconfig/appmanager/language on system hostname. Use this syntax to add an application server.
hostname:/path—specifies a directory on the remote system hostname.
localhost:—the local system-wide location. This keyword is used to alter the precedence of the local system-wide location. See Changing the Precedence of the System-Wide Local Location.
