Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Database (Action/Data Types) Search Path
The database search path directs the desktop to search specified locations for files containing:
Default Database Search Path
The default database search path includes personal, system-wide, and built-in locations. The default language is C.
Personal location—HomeDirectory/.dt/types
System-wide location—/etc/dt/appconfig/types/language
Built-in location—/usr/dt/appconfig/types/language
How the Application Search Path Affects the Database Search Path
When a location is added to the application search path, the appropriate database subdirectory is automatically added to the database search path (see How the Application Search Path Affects the Database, Icon, and Help Search Paths).
For example, if the application server hosta: is added to the application search path, the directory hosta:/etc/dt/appconfig/types/language is automatically added to the database search path.
Database Search Path Environment Variables
The database search path is assembled from the built-in locations and the following input variables:
DTSPSYSDATABASEHOSTS—system-wide database search path input variable
DTSPUSERDATABASEHOSTS—personal database search path input variable
Use these input variables to specify locations outside the application search path.
The assembled database search path is specified by the output variable DTDATABASESEARCHPATH.
Syntax for the Database Search Path Input Variables
The syntax for the variables DTSPSYSDATABASEHOSTS and DTSPUSERDATABASEHOSTS is:
VARIABLE=location [,location...]
where location can have the syntax:
/path—specifies a directory on the local (session server) system. Use this syntax to add a local directory.
hostname:—specifies the system-wide directory /etc/dt/appconfig/types/language on system hostname.
hostname:/path—specifies a directory on the remote system hostname.
How the Database Search Path Is Assembled
The value of the database search path (DTDATABASESEARCHPATH) is created by assembling the following locations, listed in order of precedence:
