The syntax for the variables DTSPSYSDATABASEHOSTS and DTSPUSERDATABASEHOSTS is:
VARIABLE=location [,location...]
where location can have the syntax:
/path—specifies a directory on the local (session server) system. Use this syntax to add a local directory.
hostname:—specifies the system-wide directory /etc/dt/appconfig/types/language on system hostname.
hostname:/path—specifies a directory on the remote system hostname.
