Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Setting the Value of a Search Path
You can modify the search paths on a system-wide or personal basis. Modifications are done by setting values for the system-wide or personal input variables. Any modifications you make are added to the built-in search path locations.
To See the Current Value for a Search Path (Output Variable)
    Use the dtsearchpath command to display the current values for the search paths:
		dtsearchpath -v
		dtsearchpath -u user
Search path values include these variables:
%H—used in DTHELPSEARCHPATH. The help volume name.
%B—used in XMICONSEARCHPATH. The base name of an icon file.
%M—the size of the icon file (.l, .m, .s, .t) used in XMICONSEARCHPATH.
%L—value of the LANG environment variable.
To Make Personal Modifications to a Search Path
  1. Open HomeDirectory/.dtprofile for editing.
  2. Add or edit a line that defines and exports the personal input variable.
    For example, the following line adds a location to the user's personal application search path:
    	export DTSPUSERAPPHOSTS=/projects1/editors
  3. To make the change take effect, log out and back in.
To Make System-Wide Modifications to a Search Path
  1. Log in as root.
  2. If the file /etc/dt/config/Xsession.d/0010.dtpaths doesn't exist, create it by copying /usr/dt/config/Xsession.d/0010.dtpaths.
  3. Open /etc/dt/config/Xsession.d/0010.paths for editing. Add or edit a line that defines and exports the system-wide input variable.
    For example, the following line adds a location to the system-wide help search path:
    	export DTSPSYSHELP=/applications/helpdata
  4. Inform all users on the system that they must log out and back in for the change to take effect.
