The syntax for the variables DTSPSYSICON and DTSPUSERICON is:
VARIABLE=location [,location...]
where location can have the syntax:
/path—specifies a directory on the local (session server) system. Use this syntax to add a local directory.
To specify a location on another system, use its network file name—for example, /nfs/servera/projects/icons.
