Log in as root.
If the file /etc/dt/config/Xsession.d/0010.dtpaths doesn't exist, create it by copying /usr/dt/config/Xsession.d/0010.dtpaths.
Open /etc/dt/config/Xsession.d/0010.paths for editing. Add or edit a line that defines and exports the system-wide input variable.
For example, the following line adds a location to the system-wide help search path:
export DTSPSYSHELP=/applications/helpdata
Inform all users on the system that they must log out and back in for the change to take effect.
