Use the dtsearchpath command to display the current values for the search paths:
To obtain the value for the current (login) user, type the command:
dtsearchpath -v
To obtain the value for a different user, type the command:
dtsearchpath -u user
Search path values include these variables:
%H—used in DTHELPSEARCHPATH. The help volume name.
%B—used in XMICONSEARCHPATH. The base name of an icon file.
%M—the size of the icon file (.l, .m, .s, .t) used in XMICONSEARCHPATH.
