You cannot use Create Action to create the data type for an application if any of the following conditions are true:
The data type must have additional actions associated with it other than Open and Print.
The Open action for the data type is not the action's command.
For example, you cannot use Create Action to create the data type that provides a unique icon for the directory representing the application's application group.
