The /usr/dt/app-defaults/language/UNIXbindings file provides the bindings described in the tables below.
The Delete key deletes the previous character when the UNIX bindings are enabled, and Shift-Delete deletes the next character.
Table 17–1 lists the dtpad overrides for menu accelerators and accelerator text that conflict with the UNIX bindings.
Table 17–1 dtpad Overrides
Menu Accelerators and Accelerator Text |
Override |
Dtpad*fileMenu.print.acceleratorText: |
Dtpad*fileMenu.print.accelerator: |
Dtpad*editMenu.undo.acceleratorText: |
Ctrl+_ |
Dtpad*editMenu.undo.accelerator: |
Ctrl<Key>_ |
Dtpad*editMenu.paste.acceleratorText: |
Shift+Insert |
Dtpad*editMenu.paste.accelerator: |
Shift<Key>osfInsert |
Dtpad*editMenu.findChange.acceleratorText: |
Ctrl+S |
Dtpad*editMenu.findChange.accelerator: |
Ctrl<Key>s |
Table 17–2 lists the dtmail Compose window overrides for menu accelerators and accelerator text that conflict with the UNIX bindings.
Table 17–2 dtmail Compose Window Overrides
Override |
Dtmail*ComposeDialog*menubar*Edit.Undo.acceleratorText: |
Ctrl+_ |
Dtmail*ComposeDialog*menubar*Edit.Undo.accelerator: |
Ctrl<Key>_ |
Dtmail*ComposeDialog*menubar*Edit.Paste.acceleratorText: |
Shift+Insert |
Dtmail*ComposeDialog*menubar*Edit.Paste.accelerator: |
Dtmail*ComposeDialog*menubar*Edit.Find/Change.acceleratorText: |
Ctrl+S |
Dtmail*ComposeDialog*menubar*Edit.Find/Change.accelerator: |
Ctrl<Key>s |
The following translations provide (GNU style) EMACS control and Meta key bindings plus some additional bindings. When appropriate, they also allow the Shift key to be used in combination with the normal binding to reverse the direction of the operation. For example, Ctrl+Shift+F will move the cursor backward a character since Ctrl+F normally moves it forward a character.
The additional bindings are:
Ctrl+comma—backward-word
Ctrl+Shift+comma—forward-word
Ctrl+period—forward-word
Ctrl+Shift+period—backward-word
Ctrl+Return—end-of-file
Ctrl+Shift+Return—beginning-of-file
GNU EMACS binds delete-previous-character() rather than delete-next-character() to the Delete key. Meta+F is normally the mnemonic for the File menu, so the binding to forward-word() will be ignored. Use one of the other bindings for forward-word (for example, Ctrl+period).
Table 17–3 lists the DtEditor.text Translations
Table 17–3 DtEditor.text Translations
Modifier Key |
Key |
Action Routine |
c ~s |
<Key>a: |
beginning-of-line()\n\ |
c s |
<Key>a: |
end-of-line()\n\ |
c ~s |
<Key>b: |
backward-character()\n\ |
c s |
<Key>b: |
forward-character()\n\ |
c ~s |
<Key>b: |
c s |
<Key>b: |
backward-word()\n\ |
m ~s |
<Key>b: |
m s |
<Key>b: |
forward-word()\n\ |
c ~s |
<Key>d: |
delete-next-character()\n\ |
c s |
<Key>d: |
delete-previous-character()\n\ |
m ~s |
<Key>d: |
kill-next-word()\n\ |
m s |
<Key>d: |
kill-previous-word()\n\ |
c ~s |
<Key>e: |
end-of-line()\n\ |
c s |
<Key>e: |
c ~s |
<Key>f: |
c s |
<Key>f: |
m ~s |
<Key>f: |
forward-word()\n\ |
m s |
<Key>f: |
c |
<Key>j: |
newline-and-indent()\n\ |
c ~s |
<Key>k: |
kill-to-end-of-line()\n\ |
c s |
<Key>k: |
kill-to-start-of-line()\n\ |
c |
<Key>l: |
redraw-display()\n\ |
c |
<Key>m: |
newline()\n\ |
c s |
<Key>n: |
process-up()\n\ |
c ~s |
<Key>n: |
process-down()\n\ |
c |
<Key>o: |
newline-and-backup()\n\ |
c ~s |
<Key>p: |
process-up()\n\ |
c s |
<Key>p: |
process-down()\n\ |
c ~s |
<Key>u: |
c s |
<Key>u: |
c ~s |
<Key>v: |
next-page()\n\ |
c s |
<Key>v: |
previous-page()\n\ |
m ~s |
<Key>v: |
m s |
<Key>v: |
next-page()\n\ |
c |
<Key>w: |
kill-selection()\n\ |
c ~s |
<Key>y: |
unkill()\n\ |
m |
<Key>]: |
forward-paragraph()\n\ |
m |
<Key>[: |
backward-paragraph()\n\ |
c ~s |
<Key>comma: |
c s |
<Key>comma: |
forward-word()\n\ |
m |
<Key>\\<: |
beginning-of-file()\n\ |
c ~s |
<Key>period: |
forward-word()\n\ |
c s |
<Key>period: |
m |
<Key>\\>: |
end-of-file()\n\ |
c ~s |
<Key>Return: |
end-of-file()\n\ |
c s |
<Key>Return: |
~c ~s ~m ~a |
<Key>osfDelete: |
~c s ~m ~a |
<Key>osfDelete: |
delete-next-character() |
