Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
General Syntax of the Front Panel Definition
Each component in the Front Panel is defined separately using the syntax:
COMPONENT name
   KEYWORD       value
   KEYWORD       value
Some keywords are required, others are optional. For more information, see the dtfpfile(4X) man page.
PANEL Definition
The PANEL is the top-level component. Its definition includes:
BOX Definitions
A BOX definition describes:
CONTROL Definitions
A CONTROL definition describes:
SUBPANEL Definitions
A SUBPANEL definition describes:
SWITCH Definition
The SWITCH definition describes:
