Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Remove a Control
  1. Create a Front Panel configuration file:
    • System-wide: /etc/dt/appconfig/types/language/name.fp
    • Personal: HomeDirectory/.dt/types/name.fp
  2. Copy the definition of the control you want to delete to the new file.
    If the control is built-in, its definition is in /usr/dt/appconfig/types/language/dtwm.fp.
    You do not need to copy the entire definition. However, the portion you copy must include the fields CONTAINER_NAME and CONTAINER_TYPE.
  3. Add the DELETE field to the definition:
    	DELETE			True
  4. Save the configuration file
  5. Choose Restart Workspace Manager from the Workspace menu.
    For example, the following control definition placed in the file /etc/dt/appconfig/types/language/TrashCan.fp removes the Trash Can control from the Front Panel.
    CONTROL Trash
      CONTAINER_NAME  Top
      CONTAINER_TYPE  BOX
      DELETE          True
