The Front Panel is assembled from all the configuration files located on the actions database search path.
Where there is a conflict between components of the definition, precedence rules determine which definition is used. Two components are in conflict with one another when they:
Have the same control name, CONTAINER_NAME, and CONTAINER_TYPE.
Compete for the same position (by having different names but
the same CONTAINER_NAME, CONTAINER_TYPE, and POSITION_HINTS).
The Front Panel uses the following precedence rules:
If components have the same control name and container name and type, the component read first is used.
For example, if both a system-wide and built-in control contain these fields but are otherwise different:
CONTROL TextEditor
CONTAINER_TYPE BOX
CONTAINER_NAME Top
then the system-wide control has precedence.
If two components complete for the same position, they are placed in the order in which they are read.
For example, if a user creates a new personal control for the Main Panel
(CONTAINER_TYPE BOX and CONTAINER_NAME Top) and assigns it POSITION_HINTS 5, the personal control will
bump the built-in control and all other controls with higher position numbers
one position to the right.
When you are modifying a control by creating a new system-wide
or personal version of it, the new control definition must specify the same
and CONTAINER_TYPE. Otherwise,
the new control will appear in addition to the existing control.
