Create a Front Panel configuration file with the control definition.
Create the icon for the control. The recommended size is 16 by 16 pixels.
For example, the following control puts a Terminal control in the switch.
CONTROL SwitchTerminal
TYPE icon
CONTAINER_NAME Switch
CONTAINER_TYPE SWITCH
POSITION_HINTS 3
ICON Fpterm
LABEL Terminal
PUSH_ACTION Dtterm
HELP_TOPIC FPOnItemTerm
HELP_VOLUME FPanel
The control uses a built-in icon and the same help topic used by the Terminal control in the Personal Applications subpanel.
