Creating a new Front Panel may be preferable when you want to make extensive changes.
To avoid conflict with the built-in Front Panel components, an entirely new Front Panel should use new names for the PANEL and other containers.
Create the PANEL component for the new Front Panel. Give it a unique name:
PANEL front_panel_name
Create the new boxes and controls, using the new container names.
If you want to use existing components, you must copy their definitions and change the CONTAINER_NAME value.
Choose Restart Workspace Manager from the Workspace menu.
