Create another control definition with the same:
control_name
For example, the following two controls are defined in two different configuration files. The controls have the same control name and container name and are therefore considered the same control.
Definition in /etc/dt/appconfig/types/C/SysControls.fp:
Control ImportantApplication { CONTAINER_NAME Top CONTAINER_TYPE BOX POSITION_HINTS 2 … }
