This section describes the main directories included in your desktop environment.
This directory is the Solaris CDE installation location. It can also be the mount point from a remote file server. Table 6–1 describes the /usr/dt subdirectories.
Table 6–1 /usr/dt Subdirectories|
Subdirectory |
Description |
SCDE applications and utilities |
SCDE run-time shared libraries |
Default system configuration files |
[Optional] Man pages |
Default application resources |
Default application icons, types, and actions |
[Optional] CDE code/program examples |
[Optional] Developer include files |
Color palettes |
CDE AnswerBook documentation and default backdrops |
This directory contains customized workstation-specific configuration files. These files enable you to customize your environment in the following ways:
Set X-server configuration options
Use multiple screens
Customize workstation action files, data types, icons, and fonts
This directory is used to store temporary files for Solaris CDE applications such as Login Manager and Application Manager.
This directory contains user specific files that relate to the user's desktop setup. They include applications, color scheme, Workspace menu and Front Panel modifications, and error logs.
