Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Customizing Mail Printing
The CDE Mailer prints mail messages using the Print action that is defined for the DTMAIL_FILE data type. It does not use the print script specified by the OpenWindows Mail Tool. To change the print behavior you must modify this Print action.
To Modify the Print Action
  1. Using your favorite editor, create the following file:
    	HomeDirectory/.dt/types/dtmail.dt
  2. Enter the following lines into this file:
    	# Override default Print action for mailboxes
    	ACTION Print
        LABEL           Print
        ARG_TYPE        DTMAIL_FILE
        TYPE            COMMAND
        WINDOW_TYPE     NO_STDIO
        EXEC_STRING     sh -c ' \
                        dtmailpr -p -f %(File)Arg_1% | mp -m -l | \
                        dtlp -u %(File)Arg_1%;'
    Note –
    dtmailpr is a print filter that strips out attachments, resulting in a stream of plain text. dtlp is the standard CDE interface to lp. %(File)Arg_1% is the file being printed.
  3. Modify the EXEC_STRING to include the print commands you want.
  4. Restart Mailer.
