Create a copy of the Xserver file by typing the following command and pressing Return:
# cp /usr/dt/config/Xservers /etc/dt/config/Xservers
/etc/dt/config/Xservers overrides /usr/dt/config/Xservers.
Edit the /etc/dt/config/Xservers file to set up two frame buffers (screens):
Choose Reset Login Screen from the Options menu.
When running Solaris CDE on multiple screens, a Front Panel is displayed on each screen. These Front Panels are independent of each other and have separate configuration files.
