For an example of creating the registration package directories for an application, see Step 3 of Example of Creating a Registration Package.
The registration package is the group of desktop configuration files used by the desktop to provide a graphical interface for the application.
The desktop configuration files include:
Action and data type definition files
Icon image files
An application group directory and its contents
Optionally: help data files and a Front Panel configuration file
The registration package is gathered under a top-level directory called the application root, or app_root.
The major categories of configuration fields under the app_root/dt/appconfig directory are shown in Table 5–1.
Table 5–1 Configuration Fields Major Categories|
Subdirectory |
Contents |
types |
Action and data type definition files |
help |
Desktop help files |
icons |
Bitmap and pixmap image files used by the application's actions and data types |
appmanager |
The directory and contents that create the application group |
Each of the major categories has subdirectories for language-dependent files. Default-language files are placed in the C directory.
Create these directories. If you are providing language-dependent configuration files, create a separate directory for each language. If you are supplying only one language, put the files in the C directory.
app_root/dt/appconfig/types/language
app_root/dt/appconfig/help/language
app_root/dt/appconfig/icons/language
app_root/dt/appconfig/appmanager/language/appgroup_name, where appgroup_name is the name of the application group.
For example, Figure 5–5 shows Application Manager containing an group whose appgroup_name is “Media_Tools.”
The dtappintegrate tool operates only on the desktop configuration files in the types, help, icons, and appmanager directories. The application's binary executable, app-defaults, and message catalog files are administered separately.
