Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Change Applications for the Initial Session
You can specify alternate applications to start as part of a user's initial session.
  1. Copy /usr/dt/config/language/sys.session to /etc/dt/config/language/sys.session.
  2. Modify the new sys.session file.
    Each entry in sys.session appears as:
    	dtsmcmd -cmd command_and_options
    To start an additional application as part of a user's initial session, specify a new sys.session entry with a full path name. For example, to start /usr/bin/X11/xclock as part of a user's initial session, add an xclock entry to /etc/dt/config/C/sys.session:
     	# Start up xclock...
     	dtsmcmd -cmd "/usr/bin/X11/xclock -digital"
