Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Error Log Locations
Choose Failsafe Session from the Solaris CDE Login screen's Option menu to bypass the normal Xsession startup to look at error logs and fix possible user dot file problems. Table 3–1 shows the error logs and their locations.
Table 3–1 Error Log Locations
Location
Error Log
/var/dt/Xerrors
Solaris CDE login window system errors prior to user login
HomeDirectory/.dt/startlog
Solaris CDE startup errors during Xsession, .dtprofile, .login, or .profile
HomeDirectory/.dt/errorlog
Solaris CDE errors after Xsession startup
HomeDirectory/.dt/sessionlogs
Directory of session logs for Session Manager and Window Manager errors
Some errors are also displayed in the System Console window. If the System Console window is not running, the fallback console log file name is wscon with the time/display code concatenated. For example:
/usr/tmp/wsconAAAa004EE:0.0
