The Workspace Manager gets information about the window menus, workspace menus, button bindings, and key bindings from a configuration file.
It uses one of the following files:
Built-in file: /usr/dt/config/language/sys.dtwmrc
The Workspace Manager searches for a configuration file in the order shown above, and uses the first one it finds.
For users who use more than one session language, a personal, language-dependent configuration file HomeDirectory/.dt/language/dtwrmc can be created that takes precedence over HomeDirectory/.dt/dtwmrc.
The personal Workspace Manager configuration file is HomeDirectory/.dt/dtwmrc. If this file exists, it is the file used.
Double-click Edit Dtwmrc in the Desktop_Tools application group.
If you already have a personal dtwmrc file, it is loaded into the editor. If not, sys.dtwmrc is copied to HomeDirectory/.dt/dtwmrc, which is then loaded into the editor.
Edit the file.
Exit the editor.
The file is saved as your personal dtwmrc, regardless of its original source.
The system-wide Workspace Manager configuration file is /etc/dt/config/language/sys.dtwmrc.
This file is not used if HomeDirectory/.dt/dtwmrc exists.
Use the syntax:
include
path
path
For example, the following lines source in the file /users/ellen/mymenu:
include
/users/ellen/mymenu
Include statements are useful for providing additional functionality without copying the entire configuration file. For example, a user might want to create a new key binding without having to administer the entire configuration file. The user can create a file HomeDirectory/.dt/dtwmrc with this content:
include
/etc/dt/config/C/sys.dtwmrc
Keys DtKeyBindings
Alt<Key>F5 root f.menu Applications
Menu Applications
"GraphicsApp" f.exec "/usr/bin/GraphicsApp/GApp"
The Workspace Manager must be restarted in order for changes made to the configuration file to take effect.
Choose Restart Workspace Manager from the Workspace menu (press mouse button 3 when the pointer is on the backdrop).
