Only properties unique to a text pane object are described here. See "Property Editor: Universal Properties" for descriptions of Object Type, Objects, Object Name, Initial State, and Color. See "Property Editor: Common Properties" for descriptions of Border Frame, Position [XY], Size, Popup Menu, and Menu Title.
Specifies whether the text pane in the compiled application and in test mode will be Editable or Read-Only.
Specifies whether words will be wrapped to the following line when the Size W(idth) value is reached.
Specifies the initial value to be displayed in the text pane in the compiled application or in test mode.
